1991 lazy daze chevy tail lights November 04, 2013, 11:04:31 pm Yahoo Message Number: 143458The drivers side rear tail light is dim and the blinker does not work when the head lights are on. The mechanic said they should be replaced but dont know where to purchase the entire assembly beacuse the tailights seem to be riveted.
Re: 1991 lazy daze chevy tail lights Reply #1 – November 04, 2013, 11:11:05 pm Yahoo Message Number: 143459Just wondring if anyone knows where I can find these or how to repair them. Thanks!!
Re: 1991 lazy daze chevy tail lights Reply #2 – November 05, 2013, 12:44:37 am Yahoo Message Number: 143462Your trail light problems may be electrical and not the tail lights themselves. Verify the voltage at the tail lights, a 22 year old MH can develop a lot of poor connections or dirty sockets.If the cans or sockets are too corraded or rusted, consider replacing all four with LEDs. They are very resonably priced, compared tojust a few years ago when they were an expensive upgrade. Terry Tanner's Technoz site has detailed instructions on replacing older LD tail lights with LEDs, check in the "Files". .http://groups.yahoo.com/neo/groups/Techsnoz/conversations/messages. Your LD would use 4" Round, Run/Turn/Stop LED Flange-mount tail lights.Larry
Re: 1991 lazy daze chevy tail lights Reply #3 – November 05, 2013, 11:11:11 am Yahoo Message Number: 143465Thanks I will check it out Ron RQuote On Nov 4, 2013, at 22:44, lw5315us@...> wrote:Your trail light problems may be electrical and not the tail lights themselves. Verify the voltage at the tail lights, a 22 year old MH can develop a lot of poor connections or dirty sockets.If the cans or sockets are too corraded or rusted, consider replacing all four with LEDs. They are very resonably priced, compared tojust a few years ago when they were an expensive upgrade. Terry Tanner's Technoz site has detailed instructions on replacing older LD tail lights with LEDs, check
Re: 1991 lazy daze chevy tail lights Reply #4 – November 05, 2013, 11:12:26 am Yahoo Message Number: 143466I had a similar issue with my Chevy. Pulled all 6 lenses off, took a scotchbrite pad (or similar) and cleaned the bulb sockets. Then sprayed with Corrosion X and installed all new bulbs across the back. I put a small bead of silicone on the surface that the lens presses up against (O-rings were basically toast) to prevent any future water or moisture from getting into the lights. They've been bright and working great ever since.Jim To: lifewithalazydazerv@yahoogroups.com From: ereinhardt72@... Date: Mon, 4 Nov 2013 21:11:04 -0800 Subject: [LD] RE: 1991 lazy daze chevy tail lightsJust wondring if anyone knows where I can find these or how to repair them. Thanks!!
Re: 1991 lazy daze chevy tail lights Reply #5 – November 10, 2013, 10:38:34 pm Yahoo Message Number: 143560We had a similar problem .. Turned out to be a ground wire issue .
