Walkie Talkie Tip October 31, 2013, 04:27:38 pm Yahoo Message Number: 143359One of the best investments we've made since buying our '99 RB last Fall has been in an inexpensive pair of Motorola Walkie Talkies (2 Way Radios) - about $50 from Walmart (free shipping). We use them when backing in and to communicate after we disconnect at the park office and head to our sites. Also handy when checking the signal lights or working outside the rig during set up/take down hookup/disconnect etc. Saves a lot of wear and tear on our relationship!!Todd & Steve '99 RB and '02 Honda CRVhttp://www.walmart.com/ip/Motorola-MH230R-23-Mile-Two-Way-Radio-with-22-Channels-121-Privacy-Codes-NOAA-Alert/10913179 Once you get a channel set up, the walkie talkies retain that setting and use is as easy as turning on/off. Am amazed at the number of couples we see, usually the wife is stationed at the back of the campsite and motions helplessly as the husband backs in.
Re: Walkie Talkie Tip Reply #1 – October 31, 2013, 04:32:44 pm Yahoo Message Number: 143361"Am amazed at the number of couples we see, usually the wife is stationed at the back of the campsite and motions helplessly as the husband backs in. "I've read of at least one case where a man caused his wife's death by pinning her against their garage in just such a situation. I second your recommendation of a pair of FRS or GMRS walkie talkies (and Motorola is a good brand) in these circumstances.And I'll add this: walkie talkies or not, as driver, my rule is to never move the vehicle an inch unless I can see the person guiding me, and see that they are clear of my path.Andy Baird http://www.andybaird.com/travels
Re: Walkie Talkie Tip Reply #2 – October 31, 2013, 04:52:58 pm Yahoo Message Number: 143362Yes, we do this too. It's enormously helpful in the short range beyond yelling but in the immediate vicinity. Off topic tip: we also use them on cruise ships, an ideal application when one or both of us is/are roaming the decks. TedOn Thursday, October 31, 2013 1:32 PM, "andybaird@..." wrote:
Walkie Talkie Tip Reply #3 – October 31, 2013, 08:41:56 pm Yahoo Message Number: 143363I have used 2-way radios for backing into a campsite for 25+ years. Currently we use the Motorola models. We keep the backing instructions simple. Elizabeth stands back on the left side in my vision and continually transmits (so there is no break in the signal) the voice instructions: "Left; Right; Straight and STOP." It is that easy. At a lot of campgrounds we will detach the Honda and she will drive ahead with the radio looking for an appropriate campsite. I have the bubble levels in the Honda so she can determine if a site is relatively level before we park the LD. We also have the radios when one of us is checking in at the camp office. If for some rare reason we are traveling separately (as we did from Florida to North Carolina last June with the LD pulling a U-Haul trailer) we also use the radios the entire distance. There are many other instances the radios can be helpful. Modern technology is good for us. Mike
Re: Walkie Talkie Tip Reply #4 – October 31, 2013, 11:11:50 pm Yahoo Message Number: 143364In a private email (because he couldn't post to the group due to a poor internet connection), Roger Nickey points out that some rear-view cameras--such as those sold by RV Cams--include audio from the camera to the monitor... so you can hear a person behind the rig. I actually have one of these, but have never thought of trying the audio, because I travel alone.Andy Baird http://www.andybaird.com/travels
Walkie Talkie Tip Reply #5 – October 31, 2013, 11:32:11 pm Yahoo Message Number: 143365You could put your cat out there and see it you hear her meow. I have had a system by RV Cams allmost 10 years, I think. Maybe it's because it is an older model, but the audio is very low level. If a person back there shouts loud enough into the camera, I can barely hear it in the monitor. No louder than if I rolled down the window I could hear the words anyway. Tom
Re: Walkie Talkie Tip Reply #6 – November 01, 2013, 12:41:01 am Yahoo Message Number: 143366QuoteOn Oct 31, 2013, at 10:32 PM, Tom Johnston wrote:Fuunneeee...I needed a good belly laugh! Thx!QuoteYou could put your cat out there and see it you hear her meow.
Re: Walkie Talkie Tip Reply #7 – November 01, 2013, 10:34:41 am Yahoo Message Number: 143367Traveling alone? I can see how the microphone idea could have merit. However there may be laws regarding privacy for audio monitoring unless you have a large sign on the back of your LD that clearly states you are audio monitoring things you may be running over.Doubtless more study is needed and perhaps government funding should be sought for this - - I understand large grants are available for such things. However it's clear that most of the things you may not wish to run over are either crunchy or will yelp if you hit them.bumper
Re: Walkie Talkie Tip Reply #8 – November 01, 2013, 10:44:34 am Yahoo Message Number: 143368Speaking of laws, those of you using Walkie Talkies that have both FRS and GMRS frequencies on them should be aware that an FCC license is required before using the GMRS section. CB and FRS can be used without a license, but not GMRS.Dick
Re: Walkie Talkie Tip Reply #9 – November 01, 2013, 10:57:50 am Yahoo Message Number: 143369FWIW, my backup cam on my '08 from the factory includes audio, and is fairly sensitive.Ken F in NM
Re: Walkie Talkie Tip Reply #10 – November 01, 2013, 07:12:24 pm Yahoo Message Number: 143371We have a pair, but rarely use them. We usually use our cell phones. Caveat: you need to be in service area, W-T good backup.From: Ted To: "lifewithalazydazerv@yahoogroups.com" Sent: Thursday, October 31, 2013 1:52 PM Subject: Re: [LD] RE: Walkie Talkie Tip
Re: Walkie Talkie Tip Reply #11 – November 03, 2013, 09:53:10 pm Yahoo Message Number: 143421Since cellular service is almost everywhere, cell phones can be used for guiding and for intra-campground communication. When guiding, the driver can put it on speaker thus keeping hands free and eyes off the phone and on the side mirrors to make sure the guide is always visible in either mirror.Chris H
Re: Walkie Talkie Tip Reply #12 – November 04, 2013, 09:42:49 am Yahoo Message Number: 143428I want to know which cruise line lets you travel with your LD. Lol-Dave 06 MB, Indianapolis
Re: Walkie Talkie Tip Reply #13 – November 04, 2013, 09:57:40 am Yahoo Message Number: 143430Good chuckle :-) Though I remember my folks did take their Pace Arrow sailing
Walkie Talkie Tip Reply #14 – November 04, 2013, 01:47:14 pm Yahoo Message Number: 143446Alaskan FerriesQuote Quote I want to know which cruise line lets you travel with your LD. Lol-Dave 06 MB, Indianapolis
