Mice Under the Hood- Final Answer October 23, 2013, 08:10:30 pm Yahoo Message Number: 143278I know this thread has been beat to dead recently and probably historically but I would like to offer some evidence I have found to be true. This summer I found a mouse nest under the hood of my Ford truck. This concerned me since my, new to me, 07 Lazy Daze would be parked for the MN winter a short distance away from where I park my truck. I decided to investigate mice preventative measures with my truck knowing I would need them for my LD this winter. I first removed the nest and placed snap traps under the hood baited with peanut butter or bacon grease. I started to catch at least one mouse a night but after a couple weeks decided I could not possibly clear out all the mice in my neighborhood. I left the traps in place and put two socks under the hood with about 10 moth balls in each. I have not caught a mouse since placing the moth balls.Moth balls are now under the hood of my LD. They are readily available at W*M but nasty to work with, wear rubber gloves and don't use them inside the coach unless you have very fond memories of playing in your grandmother's closet as a kid. I about poisoned myself by crawling under my boat cover with four socks of moth balls to be placed there. I came out with a hour long headache and about sick to my stomach. You don't have to scold me. I'm a chemical engineer and should know better. I remove the socks if I am going to drive my LD or truck and only get a faint whiff inside the cab on some ventilation settings.I've removed all food items and placed snap traps in the coach and will monitor the situation there throughout the winter. I was lucky with the truck and found only one chewed rubber vacuum line that had to be replaced. My last RV was destroyed by an engine fire caused by a squirrel or mouse nest on top of the exhaust manifold. I now always check the engine compartment thoroughly with a flashlight before starting it after an extended absence. As a famous cartoon character used to say- "I hate those meeses to pieces!"
Re: Mice Under the Hood- Final Answer Reply #1 – October 23, 2013, 11:42:57 pm Yahoo Message Number: 143287Say guy, why don't you get this product called "Mouse Free" From Tweety's.com, for instance. I hear it's very good...check it out..Take care...On Wednesday, October 23, 2013 8:10 PM, "gregvraspir@..." wrote:I know this thread has been beat to dead recently and probably historically but I would like to offer some evidence I have found to be true. This summer I found a mouse nest under the hood of my Ford truck. This concerned me since my, new to me, 07 Lazy Daze would be parked for the MN winter a short distance away from where I park my truck. I decided to investigate mice preventative measures with my truck knowing I would need them for my LD this winter. I first removed the nest and placed snap traps under the hood baited with peanut butter or bacon grease. I started to catch at least one mouse a night but after a couple weeks decided I could not possibly clear out all the mice in my neighborhood. I left the traps in place and put two socks under the hood with about 10 moth balls in each. I have not caught a mouse since placing the moth balls.Moth balls are now under the hood of my LD. They are readily available at W*M but nasty to work with, wear rubber gloves and don't use them inside the coach unless you have very fond memories of playing in your grandmother's closet as a kid. I about poisoned myself by crawling under my boat cover with four socks of moth balls to be placed there. I came out with a hour long headache and about sick to my stomach. You don't have to scold me. I'm a chemical engineer and should know better. I remove the socks if I am going to drive my LD or truck and only get a faint whiff inside the cab on some ventilation settings.I've removed all food items and placed snap traps in the coach and will monitor the situation there throughout the winter. I was lucky with the truck and found only one chewed rubber vacuum line that had to be replaced. My last RV was destroyed by an engine fire caused by a squirrel or mouse nest on top of the exhaust manifold. I now always check the engine compartment thoroughly with a flashlight before starting it after an extended absence. As a famous cartoon character used to say- "I hate those meeses to pieces!"
