Topic: Ford 4R100 transmission questions (Read 24 times) previous topic - next topic
Yahoo Message Number: 143058
Apology:  this is the first time we have logged onto Yahoo since all  the big "improvements," and I cannot locate the reference libraries or Q&A  pages at all, and my husband has a question about automatic transmission fluid,  so if this has been discussed elsewhere previously, we apologize.
Pat, Piscataqua River 30' LD IB
Here's Bob:
 P. River is based on the 2000 Ford E-450 chassis with the V-10 engine and  the 4R100 transmission.  It now has 42,000 miles on it, and according to  the book, is overdue for a trans fluid change.  This unit is supposed to be  filled with Mercon, but Mercon is no longer available.  Mercon V is the  official substitute, but some sources say DO NOT mix the two.  This would  mean that the trans and the torque converter should be thoroughly drained before  filling with Mercon V, and the refill should be 15 to 16 quarts.  Has  anyone had experience with this situation?  If so, did you A) do it  yourself?  B) have a Ford dealer service dept. do it? C) go to a  transmission specialist like AAMCO? or D) have an independent service shop do  it?  I recall seeing one report of a Lazy Dazer who had synthetic trans  fluid installed and wound up with a ruined tranny.
Re: Ford 4R100 transmission questions
Yahoo Message Number: 143062
"I cannot locate the reference libraries or Q&A pages"
Pat & Bob, the "Files" area is now semi-hidden under the heading "More", which appears just below the large photo on each page. Click on that word, and then choose "Files" from the popup menu that appears.
Yahoo Message Number: 143065
Pat
Confusing, isn't it? Our 2003 LD's owner manual states, in bold lettering, not to use Mercon V.
Then back somewhere in 2006, Ford decides to stop production of Mercon and that Mercon V is just fine for the 4R100. What changed?
 Here is a chart showing Ford's present ATF recommendations, for its various transmissions. machenry.com/documents/atffluidchart.pdf It shows your 4R100 using Mercon V as the replacement for Mercon.  Interestingly, Mercon is also known as Dextron III and is still available at Napa.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/A-Trans-Fluid-NAPA-Dexron-III-Mercon-1-Qt-/_/R-NCA75200_0274141270 So you do have a choice, stay with the original recommendation using Dextron III or use Ford's Mercon V replacement.
 I suspect most 4R100 model owner's have switched to Mercon V. I still wonder...
Switching to Mercon V does require a total replacement of the fluid. The flushing, done through the transmission cooler's supply line, and refilling will take about 22 quarts before the fluid run cleans.
Any competent auto mechanic should be able to do it. Transmission shops have a power flushing machine.
There are a lot of LD's running synthetic ATF.  Mobil 1 synthetic ATF is listed for transmissions using both Mercon and Mercon V. Like switching from Mercon to Mercon V, the transmission needs a through flushing when switching to synthetics.
 After seeing how clean the drained ATF is, from our LD, I'm sticking with a conventional ATF and changing at the the recommended 30,000 intervals. The E450's cooling system does a good job of keeping the transmission oil cool and from deteriorating. Synthetics may be overkill in this situation.
Yahoo Message Number: 143071
Bob,
 I change my 4R100 oil at about 38,000 miles in my 2000 SOB, dropped the pan, new filter in the pan, drained the transmission cooler and the torque converter (the 2000 models have a drain plug on the converter - take off the cover plate on the bottom and rotate the converter until you see the plug).  I refilled with Mobil 1 ATF and now have over 60,000 miles on it with no ill effects.  I did find, however, that the transmission fluid temperature on my ScanGauge II reads lower now and has never exceeded 225 degrees climbing grades in Arizona.  I even use Mobil 1 in my 20 year old Toyota pickup!
Glen
Yahoo Message Number: 143074
Bob, Glen, I just had my trans serviced at the Ford dealership in North Hollywood, Ca. It has a full truck service department, separate from car service  It's the 2nd trans servicing there (28K and 58K miles) .They did a flush and exchange of fluids using 15 units (quarts I assume) of "XT5QM Mercon Transfluid". It's $4.75 a can, $71.25 for the 15 units it takes to flush and fill. I can't tell if that's Merocn V or not. I've been using the dealership for 5 years and they seem to know what they are doing. Unfortunately, I don't know what trans I have.
Bill '03 FL E450
