Topic: cracked window (Read 8 times) previous topic - next topic
cracked window
Yahoo Message Number: 142668
Help,
I have been resealing all the windows in my '88MB and dealing a touch of dry rot along the way.  Climbed into the over cab bunk yesterday to remove the side windows and noticed that the front window has a spider crack in it.  Do I need LD glass or can I get tinted automotive glass from a local shop.  I never use the bunk, except for storage, not worried about the color of the tint.  I keep a sheet of foam in front of the window anyway to reduce heat loss during the winter.  (that's why I hadn't noticed the crack until yesterday).  Getting things ready for the winter ski season.
Thanks,
Paul
Re: cracked window
Yahoo Message Number: 142677
Hi Paul, had an '83 with a cracked cabover window. The crack itself did not leak, but caused problems with sealing the window to the frame. I replaced it with a similar thickness of Lexan, untinted, to better withstand impact and reduce thermal transmission. Like you, we kept the window covered with foam inside.
