Topic: water pump oscillates on-off (Read 3 times) previous topic - next topic
Yahoo Message Number: 142225
I have noticed on my 2010 LD MB that the water pump oscillates on/off with a very annoying sound when the shower is on or when a faucet is not fully opened. I at first thought it was the pump and replaced it but no change. Is this normal? I never had this with my 5th wheel that uses the same pump ( Shure Revolution 2008).
Thanks, Fred
Re: water pump oscillates on-off
Yahoo Message Number: 142228
Thanks, Fred
Check routing of the outlet hose. If touching a panel directly, or if an attachment is loose, the panel will vibrate with the pressure pulses.
Yahoo Message Number: 142229
Thanks, Fred
Fred, check trouble shooting guide from Shurflo and then the Lazy Daze Companion above for photo and adjustment instructions.
http://www.shurflo.com/files/RV-Installation-Manuals/4008-Revolution-Pumps/Revolution%20Pump%20911-1008-D.pdf
Joe Hamm
