Topic: Sewer outlet question (Read 6 times) previous topic - next topic
Yahoo Message Number: 142099
We are happy owners of our "new" to us 2000 30' IB LD.  But, we have a question.  We are experienced RV'ers - having had several flavors over the last 30 years.  But, we've never seen a sewer outlet connection done like this. Ours is tilted up - so you have to connect with a 90 degree connection so it will drain down.  Is this supposed to be like this?
Re: Sewer outlet question
Yahoo Message Number: 142102
You should be able to rotate the connection up and down. Does not go too far but it does give you some flexibility.
Bob in FL
__ From: mteleck jandmteleck@...>
 Sent: Sunday, August 18, 2013 6:14 PM
 Subject: [LD] Sewer outlet question
Yahoo Message Number: 142104
In other words, your sewer pipe empties straight down, right, so you would have to connect a fitting such as this http://tinyurl.com/lmf2kxo if you wanted the hose to be straight (horizontal to the ground)? I have an '02 30'and I just hook the hose right to the sewer pipe, a hose like this http://www.campingworld.com/shopping/item/ez-coupler-bayonet-sewer-kit-20/27864 and the hose bends at the top and then I extend it to the sewer dump opening. I still use the original hose which came with the new LD.
Chris H
Yahoo Message Number: 142105
Bob is correct in that you have some room to rotate the outlet.   Don't be afraid to twist it a little.  On my 2002 30' I also added a clear plastic extension (Camping World) that has about a 45 degree angle which makes hooking up the dump hose easier, and you can see when the flush water is clear.     You can leave it in place and just remember that it's there and be somewhat careful parking, etc., and you won't have a problem with hitting anything.
G N Wilson
2008 Mid-Bath
Yahoo Message Number: 142109
If you leave it on permanently, you put a cap on it when not in use, right?
Chris H
Yahoo Message Number: 142111
Congrats on the LD.. On my 2000 30 IB it comes out straight and I put a 90° clear elbow (towards the rear) and added a short (2') slinky, just enough to go through the 'drop down' door.
Jerry
Jerry Galang
Meridian, ID 83646
Yahoo Message Number: 142115
Thanks everyone for the help and comments!  It's good to know this isn't unique to us - we actually had wondered if the previous owner(s) had done some weird mods. We're taking all your input and fixing.  Thanks again!
