Topic: Propane Tank Clean Up (Read 6 times) previous topic - next topic
Yahoo Message Number: 141617
After the recent discussions about rust at the bottom of the propane tanks on many LDs, I took a good look at ours.  Not surprisingly, after 11-1/2 years and 116,000 miles we had some areas of rust and flaking paint.  I got started scraping paint off before I decided that I should take photos to document this job.  I put up a web page on our personal web account if anyone is interested.  Unfortunately, there are no "before" pictures of the tank before the loose paint was scraped.
 http://www.berggreen.org/LD/propane.html
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: Propane Tank Clean Up
Yahoo Message Number: 141626
Art
Easy way to deal with rust is to wire brush loose rust off. Then apply Jabsco Metal-Prep (green fluid in translucent bottle as Home Depot).
 This uses delute phosphoric acid to convert rust and then you can simply paint over it.
bumper
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 141717
older_fossil  wrote: I got started scraping paint off before I decided that I should take photos to document this job.  I put up a web page on our personal web account if anyone is interested.
--- Art, did you use a separate primer after the scraping, sanding, and rust converter? Which "finish" paint did you use? Rustoleum gloss white?  Other?  Thanks for any details.
Yahoo Message Number: 141719
Hi Joan,
 After scraping, sanding and wire brushing, I applied Rustoleum Rust Reformer, followed by Krylon flat white primer and then several light coats of Rustoleum Gloss White Protective Enamel.
Art
Art and Barbara
Art's blog
Yahoo Message Number: 141736
older_fossil  wrote: After scraping, sanding and wire brushing, I applied Rustoleum Rust Reformer, followed by Krylon flat white primer and then several light coats of Rustoleum Gloss White Protective Enamel.
--- Thanks, Art! I checked the tank underside a few months back and didn't see any rust or suspicious "lesions", but it's time to do it again.
