Topic: Metal Coach Door Catch! (Read 11 times) previous topic - next topic
Yahoo Message Number: 138292
Does anyone know where I could pickup a metal coach door catch for the main door on a '06 23.5 rig.  I have not yet contacted the plant as I am trying to find an easier fix.  Any help would be appreciated.  Thanks...............mike
Re: Metal Coach Door Catch!
Yahoo Message Number: 138340
And here's another question.....my 2008 has the metal coach door catch at the top of the door instead of in the middle where it used to be.  I find I have to really "slam" the door hard to get it to catch.  Is this normal?   Sooner or later something is going to break, probably the door!  Any suggestions?   Thanks,   Gale
G N Wilson
2008 Mid-Bath
Yahoo Message Number: 138342
What we do is to push high on the door to get it to latch with less force and twisting on the door. This is a more difficult leverage point for pushing, but the trick is to use just enough momentum from the door to get it to latch, always keeping a little pressure from your hand as high up as possible. Takes a little practice, but it works well.
Yahoo Message Number: 138343
I also would recommend spraying some silicon into the latch mechanism.  We had a problem with the door latch being hard to shut, and a quick spray of silicon seems to have solved the problem for now at least.
barry
Yahoo Message Number: 138346
When we bought a metal clip from the factory to replace the plastic clips that kept breaking, we were advised to keep a little grease on it.  A lack of lubrication can cause the metal catch to eventually break.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
