Low Spot On Roof April 12, 2013, 08:36:02 am Yahoo Message Number: 138233I wonder if LD designs a low spot in the roof just above the driver, or it just happens ? Both of mine, an '04 24 & '06 26 had them, along wit 2 others I've had an opportunity to look at had nearly identical spots. Especially agitating when it dumps its contents on you and the open door .
Re: Low Spot On Roof Reply #1 – April 12, 2013, 09:33:10 am Yahoo Message Number: 138236Quote I wonder if LD designs a low spot in the roof just above the driver, or it just happens ? Both of mine, an '04 24 & '06 26 had them, along wit 2 others I've had an opportunity to look at had nearly identical spots. Especially agitating when it dumps its contents on you and the open door . Because of the flat roof and dams caused by the sealant along the front and sides, 'Lake Newton' is inevitably formed when you level the rig and it rains. I would have thought one soaking would be enough to remind one to keep the door and window closed when coming off the blocks?Steve
Re: Low Spot On Roof Reply #2 – April 12, 2013, 10:39:58 am Yahoo Message Number: 138238It even has a name ! Some of us are just slow learners I guess. It even took me a couple of times stepping up on the "running board" to learn that method of spinal compression .Dave W
