Topic: Fuel Pump backup update (Read 6 times) previous topic - next topic
Yahoo Message Number: 138087
The added inline fuel pump will draw fuel through an inoperative OEM pump. The OEM pump will push fuel through the aux pump but I don't intend to use it that way.
All that remains is to control the pressure.
First attempt will be to control the aux pump with the OEM power source. It would really be slick if this works.
 I have found a $30 mechanical regulator whose return line can go to the generator fuel line so it looks like, one way or the other  the problem is solvable.
 For $100 and a little prep work you can beat the tow charge, drive your tank dry, and either take it to a service center or repair it yourself.
Harry 2006 RB.
Harry 2006RB
