Topic: converter replacement for Magnatek 6345 (Read 10 times) previous topic - next topic
Yahoo Message Number: 138032
Researching replacement of either a Parallex 7345 RU or Progressive Dynamics PD 4645 upgrade. Would appreciate comments on either as direct replacement. Will have tech do the removal and replacing. Is one preferable? We most always plug in to shore, rarely boondock- use the Trojan T-105's. Original Magnatek boiled batteries way too often. LD is a 2000 IB. TIA for comments. Norma  (LD 2000 IB)
Re: converter replacement for Magnatek 6345
Yahoo Message Number: 138042
Perhaps put a timer on the charge line while in storage, 1 hour a day will suffice. No boiled batteries saves power.
Sent by wireless
Yahoo Message Number: 138044
Norma, several of us have installed this upgrade kit from Best Converter.  Easy install and 3 way charger.  You can call or email them for recommendations as well.  They do respond quickly.
http://www.bestconverter.com/45-Amp-Converter-Replacement-Kit_p_46.html#.UV8y2d3GQYg
Joe Hamm
Yahoo Message Number: 138070
To answer your question directly, Norma, the Progressive Dynamics PD 4645 converter is generally regarded as superior to the Parallax--easier on your batteries, and probably a bit faster charging as well, due to its intelligent 3-stage charging circuitry. The upgrade kit that Joe recommended is the way I'd go it I were you.
Andy
Yahoo Message Number: 138097
Thanks Andy. That is what I was looking for.  My research thru the LD group indicated the progressive dynamics. My tech suggested the other, and I wasn't sure if there was discernable difference. I'll go with LD experience. Thanks to all for answering my request. It is a pleasure to be associated with this group of helpful people. Norma
