Topic: Plumbing vent cap (Read 8 times) previous topic - next topic
Plumbing vent cap
Yahoo Message Number: 137984
While on the roof I noticed a slight reddish stain alongside the metal vent cap at the toilet location.
 The round cap appeared ok but when I touched the lip of the stack a rusted piece of it fell away onto the roof.
 I see that they have plastic ones and metal. Other than UV working on the plastic is there any advantage to metal over plastic?
Jim C
Re: Plumbing vent cap
Yahoo Message Number: 137996
Why bother with a vent cap ? Ever see one on a house ? Just make sure the vent pipe is well sealed.
Dave W still sitting
20 + MH's since 1977 incl...
Past
FMC, 2x GMC's, Foretravel, 2x LD
Present
1996 LD RB under restoration, my project to keep me off the streets.
Yahoo Message Number: 138001
What!... Do you mean sealing off the vent or around the mounting? Anyway, the roof vent on a house collects rainwater and dumps it into the sewer system. On the rig, it would collect in the tanks, which have a limited enough capacity. Keep the cap.
Yahoo Message Number: 138011
I kinda figured that it would be clear to most that I meant the vent pipe penetration thru the roof be well sealed, sorry for my short sightedness.
How much water
Past
Present
Yahoo Message Number: 138012
"I kinda figured that it would be clear to most that I meant the vent pipe penetration thru the roof be well sealed, sorry for my short sightedness.
How much water in your tank do you figure you'll get from a inch of rain ?"
Dave
 A RV-style vent cap allow vertical movement of the vent pipe and is a proven item, used on millions of RVs.
I'm not too worried about a little rain water entering the vent pipe, being much more concerned about maintaining a constant seal between the vent pipe and the roof, a leak there could be costly.
RV vent caps are designed for the this application and are available at any RV store, I have even seen them at Wal-Mart.
It's a $3.00 item, splurge.
http://www.rvplus.com/hengs-industries-plumbing-vent-col-wht-10002-c.html?utm_source=shopzilla&utm_medium=cpc&utm_campaign=rv_shopzilla
2001 MB
Yahoo Message Number: 138015
Rather than rain, maybe it has something to do with driving down the road at 60 mph, something you don't usually do in your stick-built home.
Could it sound like a big organ pipe, or force fumes into the vehicle?
Eric Greenwell
2005 Jayco 24SS
Yahoo Message Number: 138018
I appreciate the responses. However, I was curious as to the pros and cons of plastic vs metal. I realize that UV works on plastic although I used 303 on other plastic items and I see what the downside is on the metal.
 I am also puzzled on why this has rusted in the first place. I saw some comments elsewhere and someone stated that these should last the life of the rig. I don't see any evidence of rusting on the others.
 Also, in case I wasn't clear it isn't the rounded cap that is rusting and breaking apart but the lip of the vertical pipe under the cap.
Jim C
Yahoo Message Number: 138019
My suspicion is that the top couple inches of the pipe condenses water and is always moist.  Maybe not while driving.  They say rust never sleeps.
John
