Topic: clogged bathroom sink drain (Read 9 times) previous topic - next topic
Yahoo Message Number: 137932
I realize this is not a unique LD problem, but wonder if the plumbing (pipes, fittings, and waste tank) in an rv requires special care when choosing a product to clear a clogged drain.  I assume that, in general, one wants to minimize the use caustic fluids, while still solving the problem.
 Any suggestions for the appropriate product to use?  Of course, I would rather pour something down the drain than remove the trap, etc. to remove the blockage, but I can do the latter if necessary.  What's the best approach?
Thanks.  Ted
Re: clogged bathroom sink drain
Yahoo Message Number: 137933
I forgot to mention that we have a 2004 RB and that the flow has slowed a lot over time, but water still drains.  It's not a complete blockage--yet.  Ted
Yahoo Message Number: 137936
LD uses ABS plastic for the drain pipes and holding tanks, the same material used in modern home drain pipes.
Household drain chemicals, used according to directions, can be used with harming the plumbing.
 Instead of chemicals, I used a garden hose with a pistol-type nozzle to clean the sink and shower drains.
Push the nozzle into the drain and pull the trigger. I try to leave a 1/4-1/2" gap between the nozzle and the drain, just in case the blockage is total and doesn't clear. You don't want to blow a pipe fitting apart.
I do this regularly as  preventative maintenance or when a drain starts draining slowly.
Expect to get splashed a little.
Drop-in drain screens will help prevent future problems.
2001 MB
Yahoo Message Number: 137940
don't forget that you could use something like one of these : http://tinyurl.com/cspmc9b
That's the Zip-It clog snag tool.. If you can remove the drain plunger and just stick this down the hole and see what you get.. I did this on a home shower recently that was running slow and hadn't been cleaned in about 5 years and the stuff that came up was really gross..  That was the best $2 I spent without resorting to harsh chemicals.. This tool is a disposable tool that's generally good for a single use and toss it out when done.  A suggestion would also to have a few spare plastic grocery bags handy in which to catch the crud that is pulled out and to ensure any drippies get caught and don't fall on the floor..
YMMV!
Yahoo Message Number: 137949
"Any suggestions for the appropriate product to use?"
Thanks.  Ted
Okay Ted, best way to go cheap and simple is to use ordinary bleach (yeah, Clorox) which can be found in any home improvement store or pool supply store or grocery outlet. Pour a sufficient quantity to fill the trap and leave it sit overnight if possible. You'll be amazed at how well it works. Reapply as many times as necessary.
Lazy Bones & Jiggs
Yahoo Message Number: 137981
Thanks everyone for your suggestions.  I find it interesting that not one of you suggested a commercial chemical product.  Thanks--Ted
