Topic: 1985 LD generator (Read 3 times) previous topic - next topic
1985 LD generator
Yahoo Message Number: 137928
I was wondering if it is possible or does any one know if the 1985 mid-bath LD has the capability of having a generator installed. thanks
Re: 1985 LD generator
Yahoo Message Number: 137944
On 2013-04-01 10:40, Natalie wrote:
I can't speak to the '85 Midbath (we've got the '85 multiplan) but you could always use something like one of the portable Honda gensets that can be placed in the shower when driving -- we've got an UE2000 genset that we bought a number of years ago and it is about the size of a small suitcase and about 60lbs give or take.. However, if you go that route make sure you lock it up as it is likely to walk away when you're not looking..
 In terms of retrofitting, if the wiring harness is not in place then I'd skip even trying as there is a lot of wiring on a genset in order to plug into the LD's existing wiring, power panels, etc..
Yahoo Message Number: 137957
My 1984 rear-bath doesn't have a generator either. I look, and the compartment where a generator could have been is not nearly strong enough to support one now. It would take welding to install one now. You'd also have to route a gas line from the truck's tank to the generator or fill the generator's tank
Yahoo Message Number: 137969
I don't THINK LD made a mid-bath model in 1985, because I don't think they were using the Ford chassis yet. Is your model 22'? If so, describe the layout of the floorplan.
Yahoo Message Number: 137971
You must have a front-lounge. Anyway, generators are not installed in compartments - that would be ripped out completely. The generator would be bolted up to the coach frame. Some frame bracing might be required. Indeed a major job and loss of storage space.
Yahoo Message Number: 137974
According to the 1985 brochure in the files section, there were only an 18', 20' and 22' in 1985.  Of course the 22' twin king is a little like the mid-bath, so that may be what they are talking about.  There is no mention of a generator either standard or optional.
Dick
Yahoo Message Number: 137990
I have seen a couple of 1985 front bath twin king 22' with a generator, both were inside the curb side compartment behind the entry door. They were both added or squeezed in after delivery.
Sent by wireless
Yahoo Message Number: 137998
thanks everyone for all the answers, i will take into thought
