Topic: Kwikee Level Best 2000 accidental deployment (Read 6 times) previous topic - next topic
Yahoo Message Number: 137555
Hi LUTZ. I have a '99 TKB and I had this almost happen near Moab Utah about 2003. Water spray from wet roads was getting in to the logic circuit board through the connector where the wire to the remote control panel plugs in.
As  soon as it dried out, operation returned to normal, i.e. the control panel  lights stopped randomly blinking, and beeping. I never experienced moving  levelers or pump activation. Guess I was lucky. I covered the connectors with  acrylic latex caulk, and I've had no problems of that type in the ten years  since. I do have an intermittent leak of a teaspoonful or so of fluid, only  when the pump is running. I've tightened all the fittings and the 'stems' of the  solenoid valves. I have a new camera that I'm going to use to find out  where the leak is. RonB and 'Bluebelle' a '99  TKB.
Re: Kwikee Level Best 2000 accidental deployment
Yahoo Message Number: 137564
Wow, good hunting on finding the leak with the camera. Visual inspection with the right lighting is a very powerful test technique. I use the old fashioned way of isolating leaks in pressurized fluid systems by taping pieces of paper towel to the suspected leak area and then see which ones got wet after a brief pressurization. For peace of mind, a positive way to prevent inadvertent leveler deployment would be to simply wire in an inline ON/OFF toggle switch in the 12 Volt line leading to the pump motor. No power to the pump = no leveler deployment. Of course for convenience the switch should be mounted in the cab. Then when you are ready to deploy your levelers just flick the switch to ON. Lutz
 Date: Wed, 20 Mar 2013 05:17:03 -0400
 Subject: [LD] Kwikee Level Best 2000 accidental deployment
