Topic: Which wax do you use? (Read 22 times) previous topic - next topic
Yahoo Message Number: 137529
Hey all! Just getting prepped for the warmer weather, and I'm curious to know which waxes or sealants any of you have used to protect against UV rays. I've got some 303 for my plastics and vinyls, but I want a polish or a wax for my painted surfaces. Thanks!
Tyler F 2001 26RB
Re: Which wax do you use?
Yahoo Message Number: 137537
Finish First Polish. Easy to apply, long-lasting - once a year application is fine, although I do the hood and cab-over twice a year.
Squished bug removal is quite easy.
wxtoad Toad Hall http://www.wxtoad.com>
Yahoo Message Number: 137538
wrote: which waxes or sealants any of you have used to protect against UV rays. I've got some 303 for my plastics and vinyls, but I want a polish or a wax for my painted surfaces.
--- Finish Kare #2180 Ultra Polymer Sealant; several vendors offer the product.
Yahoo Message Number: 137540
Tyler F 2001 26RB
Tyler, I use this rv, boat and aircraft wax.  Not saying it is better than others but had a friend who was a distributor before he retired.  Price was right.
http://www.amazon.com/Boat-Aircraft-Wax-P-38-Q-1quart/dp/B0078A0BM2
Joe Hamm
Yahoo Message Number: 137542
On Tue, 19 Mar 2013 20:35:52 -0000, "jctaylor1941" wrote:
I will agree with her on this.
2180 A.S. Ultra Polymer Sealant: The Mothership has been selling this since at least 2007. It is made by Finish Kare in El Monte, CA. It sells for $23.50 for 31oz. It goes on easy and wipes off even easier.
It's a cream in a squirt bottle. I just finished a bottle after six years. All the amino's they say are in it must make the paint happy.
 On the road, I use Protect-All in the impregnated pads. One pad will do the hood and cab doors. The rest of the rig can wait until I get home.
More choices are mentioned on The Companion.
Cheers, Don
Yahoo Message Number: 137558
I use Rejex the same protecter that we used on our boat. Kept our hull shinny and protected the surface for more than 9 years
Yahoo Message Number: 137574
You might be interested in the wax test I performed ten years ago, comparing an expensive, boutique wax against an conventional, off the shelf wax, from the local auto parts store.
See post# 28410
http://autos.groups.yahoo.com/group/lifewithalazydazerv/message/28410?threaded=1&l=1> There was no visible difference in appearance or water beading after a few months. If you want a great shine, carnuba wax is hard to beat but it doesn't long. The man-made waxes appear to remain effective much longer, helping to repel bugs, sap and other aerial debris.
 For many years, I have used one of the better polymer waxes from Mother's or Mequiars. I give the LD a once a year spa treatment, starting with a good washing, next is the deep cleaning of the paint with a clay bar kit, and, finally, sealing with a heavy coat of the polymer wax.
http://www.amazon.com/Mothers-20011-FX-SynWax-Paste/dp/B0033QNTGU>
http://www.meguiarsdirect.com/product_detail.do?q=4601>
 If I'm feeling energetic, the front end will get a second coat, as well as around the coach entry door. The process usually gets spread over several days, as the arms and shoulders permit.
The paint looks good after sitting out in the California sun for over ten years. The blue exterior trim holds up well, wish the decals were in as good of shape.
2001 MB
Yahoo Message Number: 137583
Thanks everyone, for your responses. I'll take some before and after pictures. Over the last couple years, I've been practicing with a high-speed rotary buffer, I probably have about 200 hours using it now. I'm confident that with the right wax/polish, I can reduce or even eliminate the few spots of oxidation and fading that I have. I'll take before and after pictures and post them once I get the job done. We have snow
Yahoo Message Number: 137587
Tyler, just be sure you use the right pad for the job.  Some of those wool pads will cut through the paint down to the metal before you know it.  I use this Porter-Cable with sponge pad.  Fool proof.
http://www.factoryauthorizedoutlet.com/porter-cable/porter-cable-car-buffer-dual-action-polisher
Joe Hamm
Yahoo Message Number: 137598
Agreed!  Great stuff!
Yahoo Message Number: 137610
http://www.factoryauthorizedoutlet.com/porter-cable/porter-cable-car-buffer-dual-action-polisher Joe Hamm
Thanks Joe. I use Lake Country Kompressor Pads. They make several 'levels' of cutting pads from those with a heavy cut down to those with no cut, 7 levels from heavy- to no cut. They're made for novice users, since rotary polishers can do more damage than good if you're not careful. I practiced on several older vehicles for plenty of time before touching a single pad to one of my newer vehicles. I'm excited to see my LD when its done!
Tyler F 2001 26RB
