Topic: LD won't start (Read 8 times) previous topic - next topic
LD won't start
Yahoo Message Number: 136754
Hi Dave. It is worth a try, but no one else ever seems to mention this.
Under the hood, In fine yellow print, on the black bar across the top of the radiator, Ford mentions the fuel pump shut off switch. The switch is located above the passengers right foot and can be accessed from inside. It is a collision activated switch to shut off the fuel pump in an accident.
Sometimes  it is called a 'rollover' switch. Through hearsay people have mentioned that  even slamming the door can shut it off. It is either on or off, so the symptom  of hard starting the one time doesn't indicate this switch. You probably need a  new fuel pump, but you should still check the quick, easy and cheap stuff first.  I hope this helps, and let us know what the final fix was. RonB and a '99TKB  called 'Bluebelle'
