Genset Troubleshooting Problem February 04, 2013, 06:58:31 pm Yahoo Message Number: 136658We also corrected the problem by raising the LD and crawling around under it. No need to lower the tank. We used the referenced sites and added an external 0.25 inch fuel line over the polypropylene line. If you look closely at the instructions you will see a dashed line around the vent port on the filler pipe. It's very important that this line be put on.Good luck!Diane Carlson and Ken Armock 2004 MB LD Deja Blue "They did it with a wooden pallet supported by jack stands just enough to gain access. They upgraded the 'pig tail' to a high quality hose (not LD level) and while they were at it they also replaced the plastic fuel line all the way to the generator with stainless steel. That should be the end of those problems."[Non-text portions of this message have been removed]
