Topic: Pla-cool pump(s) (Read 13 times) previous topic - next topic
Pla-cool pump(s)
Yahoo Message Number: 136571
Interestingly enough, I've become a self-styled expert on all things Pla-Cool due to just having restored a complete working unit on my '93 22' MP.
 First of all, as others have noted, you need to turn on your main coach water pump. Secondly, there is a shut-off valve (ours is located inside the Mr & Mrs closet) that operates identically to a sink faucet - it allows water to flow to the holding reservoir located up in the swamp cooler unit itself.
 The thing that automatically shuts off the water flowing up to the reservoir is a ballcock-valve - no different than what is in every  home toilet, except it's just a whole lot smaller. In my case, the entire unit was filthy from 20 years of accumulated debris, so I took it apart to get it fully cleaned. As an aside, like a toilet, you can adjust the water level in the 'bowl' if you so desire, especially if you're getting a spill out while underway.
 To get to the unit internals from the roof, there are two fasteners with auto-body type bracket screws holding the cover down. In my case, they were fully rusted, so I simply ground them off. Once off, the lid has a nice, easy moving hinge that allow you to lift it up to gain access. (If your bracket screws are destroyed like mine, they are 20 cent parts that can be replaced at any good hardware store.)
 Once you have the lid up, you can gain access to the reservoir, ballcock valve, secondary pump, sponge, water spray disk & and of course the fan. The secondary pump is what pumps the water from the reservoir through some thin surgical hose to the spinning water disk & sponge. The secondary pump is also easily removed (I did in order to clean both it and the sump filter). Once you have it out, you can test to see if it's working, or if not, search around for replacement. It is very generic, so you shouldn't have any problems.
 While you're up there, you might as well replace the tubing & clean the sponge/fan unit. In my case, the culprit was the tubing - mine was weathered & cracked, so that when I turned on the secondary pump, water was spewing everywhere all over the roof. But, for around 50 cents, I replaced the entire length.
 Everything else works fine, especially after such an extensive clean-up process. I'm a big fan of the swamp cooler, and LD was too back in the day. In fact, I have an original hand-out they provided extolling the virtues vis-a-vis A/C, not least of which is that it only pulls 3 amps DC while out in the middle of nowhere, sans generator.
 My rig's original owner, from whom we bought the RV through his family, ordered this 22' with a Tonawanda 454 (a special upgrade offered in '93), but no generator, AC or ladder/racks. I'll leave it to your imagination as to how this baby drives.
 As an aside, he didn't put on an AC unit until a trip he made to FL in July '98. I have the receipt from the Ft Lauderdale Camping World written up just a week after he left CA (from which I have the service receipts while he was getting prepped for the trip). Problem is, ain't no swamp cooler gonna work there in summer - LOL.
K
Pla-cool swamp cooler
Yahoo Message Number: 137232
Just a quick update to the post below. Last weekend, the pump finally went out on our Pla-Cool swamp cooler. (This is the pump that directs water to the spinning disk. The ma
Re: Pla-cool pump(s)
Yahoo Message Number: 154747
Hi Karl,
My name is Pat ( female).  I have been up on the roof of my 94 lazy daze to check out my swamp cooler, and so far the water pump up in the unit itself is not working.  The reservoir is getting water into it , but the pump sounds dead no ( sound from it and no water being picked up).  So your saying radio shack has a good replacement?  Can u tell me more?
Also Im not sure yet if the disk that spins the water off onto the pad is working.  Should it spin when the fan is turned on inside?  I ask that because I don't know if the lid on the whole unit has to be down for that to work.   Thanks in advance for any help you can offer with this.  Pat
Yahoo Message Number: 154748
As it turns out, my pump gave up the ghost as well. For the past few months, it has needed me to takes it out and break it loose to get it running, but this time I couldn't get it going. I need a replacement and if somebody has a model# of the motor that would be great.
The disk should spin when the fan is running- I believe it is directly attached to the top of the fan?
1989 MP
Yahoo Message Number: 154758
Jeff, I recently removed a Placool form my '91 and would like to offer it to you if you want it. The fan worked, but I honestly did not check anything else on it. The cover is cracked, but it is free for the taking. The catch is, you need to pick it up in Santa Barbara, Ca as I do not want to deal with shipping. In 4-6 weeks I may be heading down to the San Bernardino area if you happen to live around there anywhere. I could apply 12V to the pump to see if it works if you want, but you would need to take everything if you wanted it. If Jeff does not want or need it, Pat is next in line. If she does not want it, anybody who can use it is welcome to it.
Jay --
Yahoo Message Number: 154760
I recently rebuilt my pla-cool and found a ventline fan motor at a local RV parts supplier that replaced my pump.  I should have taken more pictures before sealing it up with silicon.  I did order from amazon a RadioShack Super Speed (High Speed) 9-18V DC Hobby Motor Model: 273-256 as a backup.  They both look the same and the old motor was so rusty it came out in pieces.  The disk that spins is directly attached to the fan motor and the top lid needs to be down or the water will shoot over the pad and not drip down on to it.  I still have some plastic repair to do to the cracked lid and have duct tape holding it together for now.  I am in Fontana if you need any assistance.
1997 TK
Yahoo Message Number: 154761
Jay,
Thanks for the offer, but I don't think I need to take you up on it. My unit works well- I just need to replace the pump...
-Jeff
1989 MP
Yahoo Message Number: 154762
Perfect. Thank you.
Follow up question- how does the motor affix to the plastic housing? I am having trouble getting mine apart.
1989 MP
Yahoo Message Number: 154765
There are two screws that are accessed from inside the impeller housing. Gently keep pulling on the impeller until it slips off the motor shaft. Then you may be able to see the screws in the little opening. Mine was so rusted I ended up pulling the motor housing and bearing off the shaft and then pushed the screws out from the top.
1997 TK
Yahoo Message Number: 155276
Thanks again. To get my old motor out, I needed to take tin snips to the case to split it open to then pull the shaft and detach the impellor. Then I could get at the screws.
I ordered the Radio Shack fan and found it to be a bolt-up physical match. I suppose it could still not work if the Radio shack motor was built for RPM and the  original motor was built for torque, but the original motor still moved plenty of water being in an imminent failure state (needing to be whacked with a screwdriver to start spinning) so I doubt the new motor won't perform adequately.
That said, the main fan is maxing howling noises on start up before it smooths out, making me think it is limited for this world as well. I don't suppose grease would help? Anyone know of a physically compatible motor for that one?
Thanks,
-Jeff
1989 MP
