Topic: Tire Pressure for Karl (Read 8 times) previous topic - next topic
Yahoo Message Number: 135581
Karl, Chris and others; With a GVWR of 10,500, Karl may have load  range 'D' tires, not the load range 'E' tires that are on the newer and heavier LD's today. The load range 'D' tires would have a lower maximum pressures. One other thing is that your propane capacity is probably only 8 gallons in a 10  gallon tank, unless you have a 12 gallon tank. Hope this helped. RonB and 'Bluebelle'
