Topic: Penetrating Oils for rusted bolts (Read 3 times) previous topic - next topic
Yahoo Message Number: 135462
This article came to my inbox today. With a little Google research I found this was published in 2007.
Disclaimer:
1) I did not do the test; this was sent to me, so I cannot personally verify the findings.
2) Mixing combustible fluids like acetone or laquer thinner, and working metal on metal with those mixtures without using spark proof tools may be risky.
Mike
Penetrating Oils
Machinist's Workshop MagT published some information on various penetrating oils that I found very interesting. Some of you might appreciate this. The magazine reports they tested penetrates for break out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Godwin-Singer is in Largo, FL. It is a high tech machine shop for the racing crowd.
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
Re: Penetrating Oils for rusted bolts
Yahoo Message Number: 135471
"ATF-Acetone mix."
 I can attest to this mix having used it for years. Its great for long-term soaking where the acetone will have evaporated away before actually trying to remove a nut or bolt.
Liquid Wrench and Kroll are also proven oils.
There are times where nothing will loosen a well rusted nut other than heating it with a torch.
 When dealing with rusty environments, a little anti-seize applied to the threads will keep it clean and easy to removed.
http://www.westmarine.com/webapp/wcs/stores/servlet/Product_11151_10001_965578_-1?ci_src=14110944&ci_sku=965578&cid=sc_googlepla&gclid=CMejlLTA9bMCFal7QgodVxcAkA
2001 MB
