Topic: Arby Potable Water Update (Read 6 times) previous topic - next topic
Yahoo Message Number: 135168
A Flickr member has made a valuable observation that I've just included in the narrative.
http://flic.kr/p/dtGfdm
 Safoocat noted that my use of the carbon filter during water-tank refill operations would remove the chlorine from the fill water. I agree that removing the chlorine is not a good idea since it helps keep the tank fresh. It's something I should have thought of myself a long time ago.
Thank you, Safoocat.
George
Re: Arby Potable Water Update
Yahoo Message Number: 135200
Actually, by the time the chlorine-treated water in the US gets into your tank, it's probably completed it's work, and removing the excess won't be a problem.  Unless you add additional untreated water of course.  ;)
Carbon filter OK.
Regards, Holly
Yahoo Message Number: 135201
Chlorine doesn't hang around long, and is pretty much tasteless. When reacting with organics, it produces chloramines, which are no longer useful for removing the organics, and those hang around a very long time, responsible for the 'chlorine' taste. They can also do unpleasant things to us.
Yahoo Message Number: 135203
Thank you, Holly and Steve. I really appreciate the info and will adjust the narrative accordingly. The learning never stops. This forum rocks !
George
