Topic: Bolt Torque Question (Read 3 times) previous topic - next topic
Yahoo Message Number: 129965
I recently had the drive train disconnected at the rear of the LD to
have it towed. What is the torque setting for these bolts when it's
time to reconnect the rear end again ?
Thank you
JC
Re: Bolt Torque Question
Yahoo Message Number: 129966
If it was the four bolts that connect the rear u-joint to the flange on the differential, the service manual for my 2002 E-450 lists the torque as 83 ft-lb (112 Nm).  I hope whoever removed the driveshaft marked the correct alignment before disconnecting the driveshaft.  Not keeping the same alignment could result in a driveshaft balance problem.
Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
