Topic: Home Depot LED upgrade projects (Read 15 times) previous topic - next topic
Yahoo Message Number: 129775
Where else do Americans go for their (mobile) home improvement projects?  Yes, the Home Depot.
In message #129102, I reported on using Philips 12-volt LEDs, available at Home Depot. Here's more.
 Three 3-watt LED spots have been added to the exterior of our LD to provide great night time illumination.
http://www.flickr.com/photos/lwade/7065152983/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/6919072710/in/set-72157602095132658 >
http://www.flickr.com/photos/lwade/7065373277/in/set-72157602095132658> The bulb's housing are made of  PVC 1-1/4" pipe connectors, caps and plugs.
As  mentioned in the previous posting, I compared the LEDs directly to 10 and 20-watt halogen spots (MR-11 bulbs) and found the output to be equal to about 15-watts. Having the twin aircraft-style light fixture made comparisons easy.
 Inside, all of the Lounge lights are LED, with the exception of three fluorescents.
http://www.flickr.com/photos/lwade/6918893760/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/6918891466/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/7064968687/in/set-72157602095132658>> I still have one aircraft-style light to install.
 Two capsule 3-watt LEDs were added to the kitchen fluorescent and have come up with a combination that is a close equivalent to the stock light, reducing the power consumption by about 75%.
A separate switch was added to operate the LEDs. Two small square holes have been cut in the diffuser to let the LEDs shine directly through without the light being reduced in intensity or changed in color.  Being mounted low, under the cabinet, the holes are not visible nor are they unattractive.
The stock fluorescent bulbs were retained and still work.
http://www.flickr.com/photos/lwade/7064975783/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/7064974939/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/7064979259/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/7065922509/in/set-72157602095132658/> I am very happy with the Philips capsules and like them better than most of the other replacements I have seen. The Philips capsules have a nice even light pattern, no hot spots, and at $14 each, are a great value. They do require a G4 bi-pin socket.  12-volt pucks lights have the correct base and can accommodate the capsules with trimming, to allow for the capsules larger size. The puck's glass covers usually need to be removed but that's OK since the capsules do not need covers.
http://www.amazon.com/GrayBean-MR16-Light-Socket-10-Pack/dp/B005I4J1D0/ref=pd_sxp_f_pt
http://en.wikipedia.org/wiki/Bi-pin_connector > The Philips capsules fit into the Factory late-model, pre-LED  puck lights with a little trimming of the thin reflector and removal of the glass cover.
http://www.flickr.com/photos/lwade/6918892552/in/set-72157602095132658 >      A $14 upgrade.
The stove hood light has been converted to a 3-watt LED puck.
http://www.flickr.com/photos/lwade/7065920503/in/set-72157602095132658> Another 3-watt LED, switched puck has been added under the kitchen cabinet.
http://www.flickr.com/photos/lwade/7064973967/in/set-72157602095132658>
http://www.flickr.com/photos/lwade/7065170553/in/set-72157602095132658>
 In the bath, two ceiling light fixtures have 3-watt LEDs installed, one warm-white and the other a cool-white, enabling the user to pick the right color or combination of both colors.
http://www.flickr.com/photos/lwade/6919841238/in/set-72157602095132658/>
Philips 12-volt LED bulbs from Home Depot.
Philips AccentLED 3-Watt MR11 Spot Light Bulb Model # 40986- 4000K
http://www.homedepot.com/Electrical-Light-Bulbs-LED-Light-Bulbs/h_d1/N-5yc1vZbm\ 79/R-202514339/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051> Philips AmbientLED 3.5-Watt MR11 Flood Warm Light Bulb Model #414978- 2700K
http://www.homedepot.com/Electrical-Light-Bulbs-LED-Light-Bulbs/h_d1/N-5yc1vZbm\ 79/R-202673038/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051> Philips AccentLED 3-Watt (20W) LED T3 Capsule Light Bulb Model # 41839- 2700K
http://www.homedepot.com/Electrical-Light-Bulbs-LED-Light-Bulbs/h_d1/N-5yc1vZbm\ 79/R-203001438/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051>
 It's nice to be able to light up the whole interior and use the same amount of power as one fluorescent fixture.
 Next energy project is to reduce the electrical appetite of our electronics. The quest continues.
2001 MB
Re: Home Depot LED upgrade projects
Yahoo Message Number: 129777
"Larry"  wrote: Where else do Americans go for their (mobile) home improvement projects?  Yes, the Home Depot. In message #129102, I reported on using Philips 12-volt LEDs, available at Home Depot. Here's more.
--- More!? My head just exploded. ;-)
Yahoo Message Number: 129780
Great information, Larry! I just ordered four of the Philips 3W LED capsules. Home Depot's screwed-up website wouldn't let me place an order, and there's no store nearby, so I ended up having to pay $2 more at Amazon--but they're still a good value. I've been looking a long time for an LED retrofit for halogen puck light fixtures!
Yahoo Message Number: 129783
Hi Larry,
 I'm curious about the LED mounted on the mirror arm - I'd like to do something like that. Is it a sequential lamp (if so, do you have a source and part #?), and how did you route the wires?
Eric
2005 Jayco 24SS
Yahoo Message Number: 129787
I found Terry's writeup on his Technoz site.
Go to the Techsnoz Yahoo site and join if you are not a member.
http://autos.groups.yahoo.com/group/Techsnoz/> Under "Files",  find "LEDturnsignal.pfd"
http://f1.grp.yahoofs.com/v1/8AyGT7Ih7DgO-gd4eP7eMKi1uCD8j7084NM-3nQFfHsAIiLmeKZsOmEFGMEdiHK4nmdoIZGd9gv-xKpIbbVilqpGoCiKCxA/LEDTurnSignals.pdf>
 The electronic strobe has several possible sequences. It has been a few years and I do not remember all of them. Check the link and go to the manufacturer's site for details.
2001 MB
