Topic: Ham Radio HF Antenna Mount for 10 & 20 meters (Read 13 times) previous topic - next topic
Yahoo Message Number: 129405
Hello All,
I would like to mount a 17' antenna to my LD 26.5 MB.
Any thoughts.  Ladder not vertical enough to make it easy.
Your comments most appreciated.
Dave
Re: Ham Radio HF Antenna Mount for 10 & 20 meters
Yahoo Message Number: 129409
Hello All,
Dave
/////////////////////////////////////////////////////////// You might want to go to the amature radio section of the Escapee's forum for your question.
http://www.rvnetwork.com/
Dave K6YVE  04 PleasureWay TD
2004 PleasureWay TD
Yahoo Message Number: 129411
"I would like to mount a 17' antenna to my LD 26.5 MB. Ladder not vertical enough to make it easy."
 Talk to Larry Wade. He just mounted a telescoping 16' pole on my ladder (could have been taller, but we cut it down) topped with a high-gain cell antenna. The base of the pole is bolted to a cup on the rear bumper, and the pole is secured vertically to the left side of the ladder, using adapters that Larry made. He can tell you the details; I'll try to post photos when I get a chance.
Yahoo Message Number: 129437
(17 foot)That is a BIG antenna to mount on any RV. I mounted a High Seirra Screwdriver antenna on the rear bumper of my 31' LD but don't have photo's.
Yahoo Message Number: 129438
He couldn't drive with that antenna.  At least not where there were any over-passes.  It could only be used while stationary.  In that case, the height really doesn't matter.  Lots of folks are using 30-foot and higher antennas with their RV's.
Dick
Yahoo Message Number: 129443
"I'll try to post photos when I get a chance."
 When Andy post the photos, I will explain the simple way the telescoping pole is attached to the ladder and bumper.
It isn't rocket science.
2001 MB
Yahoo Message Number: 129560
Hello All,
Dave
Hello to All Who Responded to My Request For Comments,
 I did receive a 17' antenna from ZeroFive Antennas, 20 meter 1/4 wave vertical.
 It was designed to accept a 1 1/4" to 1 5/8" mast insert.  Went to Home Depot, of course, and purchased 2 72" x 1 1/4" aluminum poles used for floating concrete and 2 strips of Velcro.  The 2 poles were combined into 1 12' mast, one end sliding into the other end of a pole,  which was then inserted into the receiving end of the antenna.  Antenna and mast raised to a vertical position beside the ladder.  Velcro was used to fasten at the top and bottom most positions available.  Also placed a block of wood under mast so as to not scratch bumper.  This will be tested in 25 mph winds in the next 2 days in the Imperial Valley near Yuma, AZ.
 Again thanks to all who responded to my query with those suggestions.
Dave (K8THH)
