Topic: 30amp plug wired backwards? (Read 9 times) previous topic - next topic
Yahoo Message Number: 129100
My shore power plug broke (the plastic housing), so I picked up a new one. When I opened the old plug I found the black and white wires reversed if I go by the markings on both the old and the new housings. Is this the way they are wired from the factory? I assume I wire it back just as I found it since everything seemed to be working fine. What gives?
Re: 30amp plug wired backwards?
Yahoo Message Number: 129105
Wire it as you found it and then use a conductivity tester to verify that is is wired correctly or, better yet, check it before you wire the new plug.
2001 MB
Yahoo Message Number: 129108
Just to make sure, convention is that white is 'neutral', green is 'ground', and the other color - black, red, or blue typically - is 'hot'.
