Xantrex Inverter - No Electrical Output March 08, 2012, 07:42:04 pm Yahoo Message Number: 129040Hi, Is anyone else experiencing problems like this? We own a 2008 30 ft with front entertainment center. We were dry docking and the television worked for approx. 5 minutes and then shut off. The battery read 13.7 volts. After that, it would not work! Thanks, Margaret and Jim
Re: Xantrex Inverter - No Electrical Output Reply #1 – March 08, 2012, 11:16:12 pm Yahoo Message Number: 129044Quote Hi, Is anyone else experiencing problems like this? Margaret and Jim The Xantrex inverter has an overload feature that will shut down the inverter at a preset voltage(check your Xantrex manual for the exact voltage). When this happens you must shut down your Entertainment center. Look behind the drawers under the refer for the inverter, turn it back on after you are sure that your solar panel is not over chargIng. All the necessary information is in your Xantrex manual. Steve
