Electric step fuse January 29, 2012, 02:07:50 pm Yahoo Message Number: 128150The electric step motor on our 1998 RB gave up the ghost. I have replaced it and door switch. There is no power to the unit. There must be a blown fuse somewhere but? ? ? ? ?? I can't find it. Anybody else had this problem?
Travasak for Sale Reply #1 – January 29, 2012, 03:33:38 pm Yahoo Message Number: 128156I have a queen microsuede Travasak for sale (burgundy). $50.We're near Quartzsite...contact me privately if you're interested.Linda Hylton http://earl-linda.blogspot.com
Re: Electric step fuse Reply #2 – January 30, 2012, 11:01:01 am Yahoo Message Number: 128178Quote The electric step motor on our 1998 RB gave up the ghost. I have >replaced it and door switch. There is no power to the unit. There must >be a blown fuse somewhere but? ? ? ? ?? I can't find it. Anybody else had >this problem? According to the Lazy Daze 2003 owner's manual, there are 3 fuses that were used with the electric step. A 5 amp mini-fuse in slot #3 on the *Ford* fuse panel under the dash; this is fuse deals with protecting an ignition lead that automatically retracts the step when the ignition key is turned on.A 5 amp mini-fuse located behind the on/off switch for the step. A 20 amp mini-fuse that is located in the house battery box at the top rear section in a labeled rubber weatherproof holder. This fuse protects circuit board box under the step mounting frame. All the above was from the LD supplied manual. I would bet on the 20 amp fuse that is in the house battery box.Good luck, Steve K.
