Antenna replacement for '02 MB December 02, 2011, 09:05:44 pm Yahoo Message Number: 127080The antenna mast snapped off my '02 MB and what I'm seeing online as a replacement is confusing. I've removed the antenna base from the roof -- looks like it was once one piece. The base portion is round with about an inch off threading then a 1/2'' probe/cable that would make the connection inside the coach.Any suggestions as to how to replace this antenna?Thanks.
Re: Antenna replacement for '02 MB Reply #1 – December 02, 2011, 10:02:39 pm Yahoo Message Number: 127081Quote The antenna mast snapped off my '02 MB and what I'm seeing online as a replacement is confusing. I've removed the antenna base from the roof -- looks like it was once one piece. The base portion is round with about an inch off threading then a 1/2'' probe/cable that would make the connection inside the coach.Any suggestions as to how to replace this antenna?Thanks. Leland? Why don't you call the Mothership and see if what they put on the LDs is available elsewhere or order a new one from the factory.Chris
Re: Antenna replacement for '02 MB Reply #2 – December 03, 2011, 11:30:47 am Yahoo Message Number: 127087Quote The antenna mast snapped off my '02 MB and what I'm seeing online as a replacement is confusing. I've removed the antenna base from the roof -- looks like it was once one piece. The base portion is round with about an inch off threading then a 1/2'' probe/cable that would make the connection inside the coach.Any suggestions as to how to replace this antenna?Thanks. Leland, you might drop in to Radio Shack to see what is available. I see they carry universal replacement mast. Could do the job. http://tinyurl.com/7rnvvpw Joe Hamm-San Jose
Re: Antenna replacement for '02 MB Reply #3 – December 05, 2011, 10:35:29 am Yahoo Message Number: 127131Thanks guys. Don't know what I was thinking. Of course LD has the antenna and they're sending one out. Thanks for the replies.L
