Topic: Interior Trim Molding for LD's (Read 12 times) previous topic - next topic
Yahoo Message Number: 126452
Ok.. For those of you that have had to remove some paneling from your LD's in the past, where did you get your replacement molding from to put back in the corners?  I gather the beaded stuff is called solid bead welt which is an extruded vinyl or rubber product.  The other material that is used is called reverse cove molding which kinda looks like a "T". Both of these are stapled in products and are installed prior to the last piece of panelling being installed.  I've not yet called the mothership and figured I'd ask here to see what others have used.  All in all I need Thanks!
-- Rick
Re: Interior Trim Molding for LD's
Yahoo Message Number: 126453
" For those of you that have had to remove some paneling from your LD's in the past, where did you get your replacement molding from to put back in the corners?
Rick
Got it from the Mothership.
It is also available in the aftermarket.
http://www.arvrepair.com/rvinterior.html>
http://www.go-rv.com/coast/do/catalog/page?index=A&pageNext=TRUE&dealerId=2637&pageNum=188>
Most bigger RV stores carry it.
2001 MB
Yahoo Message Number: 126454
On Mon, 07 Nov 2011 18:33:38 -0000, Larry wrote:
Larry-- Is this the stuff you're thinking of?  I didn't see any on the link -- this is what I'm after -- I should have provided pics earlier :
 http://www.keithsrvsurplus.com/servlet/the-232/Rv-trailer-marine-solid/Detail
here's the reverse cove molding: http://www.keithsrvsurplus.com/servlet/the-131/Rv-trailer-marine-reverse/Detail
Thx!! I probably call LD and check with them-- perhaps my names are a bit off..   I am of the opinion that these are very standard RV accessories used on virtually all RV's, but I was not able to find them on the Camping World website..
Yahoo Message Number: 126455
By the way.. Just in case nothing else pans out, this supplier appears to carry the right stuff I believe and various other things that might work for different projects.  I found this on an Airstream site and someone was looking for the same stuff and someone suggested these guys.. Their stuff is even made here in the USA..
 http://www.westandbarker.com/
Yahoo Message Number: 126456
Rick Flower  wrote: http://www.keithsrvsurplus.com/servlet/the-232/Rv-trailer-marine-solid/Detail --- You might try googling (or asking the factory for) vinyl "welting"; the stuff shown in the link photo looks just like the "seam welting" used by sewers to add a decorative touch to the seams of pillows, cushions, etc. (Different material, of course!)
Joaan
Yahoo Message Number: 126458
Ok.. You were about spot on -- I spoke w/ Todd and he informed me that the beaded material that is sometimes called welting is also called Gimp and that's the term they use.  He thought the other stuff I was asking about might be "F" molding but I'm not convinced.. Regardless, they carry what I need so I'll be trekking over there again on Friday morning -- I might also ask about the brass spiral nails which are those shiny (or dull) nails that you see holding up the ceilings and paneling throughout your rigs.  I found that I can buy them via Amazon but I won't get it until next week.. I only need a few dozen..  That should get me through this project.  My countdown is coming up fast.. more stuff to do!
