Topic: Another H20 winterizing question (Read 2 times) previous topic - next topic
Yahoo Message Number: 126189
I own a 1994 22' Lazy Daze.  When winterizing the system, is it necessary to blow out the water heater?  Or will it drain completely via gravity when I open the plug?  I plan on adding 6 gallons of antifreeze though the water intake. Do not have the talent to install a bypass valve as discussed in another message here on the forum.  Thanks.
Re: Another H20 winterizing question
Yahoo Message Number: 126195
Draining the water heater will empty it quite enough, but without the bypass, your water pump will try to refill it with the anti-freeze - a very expensive proposition.
