Topic: Winterize LD (Read 7 times) previous topic - next topic
Winterize LD
Yahoo Message Number: 126168
Dump 9 gal of antifreeze into empty fresh water tank and run pump until pink comes out each water faucet and toilet. Strainer on pump should be checked, to be full of antifreeze. Also be sure to operate toilet sprayer. So what if you have to fill hot water heater. Antifreeze only costs about the same as gasoline.
Re: Winterize LD
Yahoo Message Number: 126172
 Nine gallons, Ace?  Yikes!  I think I will stick with using my compressor to blow the lines.  It's worked well for 9 years.
Re: Winterize LD
Yahoo Message Number: 126199
Dave,
How do you add antifreeze to the pump?
Patricia  The grandma of her tribe on her 67th year adventures.
