Topic: Doran vs Tire Traker tire sensors (Read 3 times) previous topic - next topic
Yahoo Message Number: 119442
Jim, The replacement batteries I believe were about $7. each @ Radio Shack. That works out to about $70/year for ten batteries plus the AA batteries in the repeater. The receiver has re-chargeable lith-ion batteries.
The TT sensor has a screw on plastic cap that protects the innards and there has been NO issue with moisture inside the unit. This summer we did a LOT of driving in heavy rain going to Newfoundland and back.
It does sound that Doran is only trying to push their product. You have to make a choice what suites   you the best.
Mike
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
Re: Doran vs Tire Traker tire sensors
Yahoo Message Number: 119443
I have not had any moisture problems with my TireTraker sensors either.  I might be able to offer some ideas on the heat damage though.
 The rear wheels on my 2003 have braided valve stems extensions which terminate on either side of the center cap.  When the sun hits the wheel simulators just right, the simulator acts as a parabolic mirror and focus the sun on one spot.  I ended up with 2 deformed (but other wise working) sensors as a result of this.
I couldn't figure out what was going on until I was sitting
Yahoo Message Number: 119444
*Mike,
 For what it is worth, you can get the batteries for $7.50 for a package of five from the Tire Traker dealer. That works out to $1.50 a battery.
https://www.tiretraker.com/products.asp?cat=2 scroll to the bottom of the page.
 Were I to be buying a system now it would be the Tire Traker because you can replace the batteries.
Jim
Yahoo Message Number: 119449
Who would have thought that was the cause. Great observation, Rich! My sensors are on the stock valves behind the wheel covers and should not be subject to the sun. I used to use those braided extenders until one came apart (braided covered rubber hose came off the crimped connector) while installing it to the inner dual tire. Poor workmanship and design. I am sticking with the stock valves - much safer.
Mike
2004 Born Free 26'
