Holding tank water leak? December 27, 2010, 02:15:24 pm Yahoo Message Number: 119228I am an original owner of 2002MB from Florida. My fresh water tank levels have been slowly dropping with out significant water usage. Then I found that the storage compartment beneath the refrigerator was full of water, so I wet vacumed it out and it is staying dry. However, I noticed water dripping from beneath the outside shower and in a location uner where the stove is located. Unfortunately, the tanks are insulated so I cannot tell the exact location of the leak. My questions are: Could there be a leak in the tank? Or, is it possible the original water pump needs to be replaced? Or, is it possible the plumbing may be leaking even with the water pump off? Should I remove the tank insulation and try to repair the leak, or should I replace the tank completely? Any help will be greatly appreciated.Thanks, KW2002MB
Re: Holding tank water leak? Reply #1 – December 27, 2010, 02:30:56 pm Yahoo Message Number: 119229On Mon, 27 Dec 2010 20:15:11 -0000, "Kevin" springlopurple@...> wrote:QuoteCould there be a leak in the tank? Or, is it possible the original water pump needs to be replaced? Or, is it possible the plumbing may be leaking even with the water pump off? Yes, yes and yes. Kevin, you or someone is going to need to find the source of the leak. I would think the tank is the least likely source of a problem. Time to get on the floor and look around the pump and it's fittings.
Re: Holding tank water leak? Reply #2 – December 27, 2010, 05:14:36 pm Yahoo Message Number: 119230Quote "My fresh water tank levels have been slowly dropping...Unfortunately, the tanks are insulated so I cannot tell the exact location of the leak."Thanks, KW2002MB Kevin First of all, yes, you must have a leak. As to the tank being "insulated", I seriously doubt that. As far as I know, all Lazy Daze 'fresh' water tanks are located on the interior of the coach and would not require insulation. The only insulation option of which I'm aware is for the black and grey water tanks which are mounted on the exterior. You need to locate and inspect your fresh water tank for leaks and then look at your water pump for same.Good luck!Steve S. Lazy Bones & Jiggs
Re: Holding tank water leak? Reply #3 – December 27, 2010, 06:42:20 pm Yahoo Message Number: 119231Kevin:I had the identical problem
Re: Holding tank water leak? Reply #4 – December 27, 2010, 07:38:17 pm Yahoo Message Number: 119232One other place to check. The tank drain. My shut off valve is exposed
Re: Holding tank water leak? Reply #5 – December 27, 2010, 08:12:58 pm Yahoo Message Number: 119233On a MB, some of the key areas to check are in 1 place (fresh water tank outlet, water pump and associated plumbing, possibly a bypass valve if someone installed one). There is a removable panel just above the floor right where your left foot is located when standing at the sink. It might not look like it can open, but it does. Just pull it off; it's attached with velcro. You can also see a fair bit of the fresh water tank with a light and a mirror, or a small head and some flexibility. If the leak is not obvious, slip some paper towels into the areas under the pump and plumbing. Check later for signs of water. The drain could be ever so slightly open (or leaking?). A cracked drain pipe, maybe caused by the junk in that compartment pushing on it over time, could explain the water in the forward compartment.Rich
Re: Holding tank water leak? Reply #6 – December 28, 2010, 12:14:58 am Yahoo Message Number: 119235You might try turning the pump on with all the outlets turned off. If you hear it cycling off and on, your problem would be from the pump to the water valves/plumbing fittings and not
Re: Holding tank water leak? Reply #7 – December 28, 2010, 11:02:55 am Yahoo Message Number: 119239In our '83 FL, the water outlet from the tank had loosened. It was simply a screwed in fitting, so simple to tighten. Worth checking this.Steve
Re: Holding tank water leak? Reply #8 – May 20, 2011, 11:19:56 pm Yahoo Message Number: 122649All, I've also found my storage compartment to be wet. Could this be a condensation problem associated with the fresh water dra
Re: Holding tank water leak? Reply #9 – May 21, 2011, 10:39:00 am Yahoo Message Number: 122651A leaking water pump (an all to common feature) in a MB anyway, will often result in water leaking anywhere along the driver side from the bath to the forward storage compartment. Fortunately the fix is easy, determine if it's the water pump and replace it. Bad news is, if left leaking, water damage may be more difficult to repair.bumper[Non-text portions of this message have been removed]
Re: Holding tank water leak? Reply #10 – May 21, 2011, 03:07:37 pm Yahoo Message Number: 122663"I've also found my storage compartment to be wet. Could this be a condensation problem associated with the fresh water drain pipe in the rear of the compartment?" Since condensation only occurs when humid air meets a cold surface, and your water tank and drain pipe are generally at ambient temperature, it's unlikely that your problem is condensation. Chances are you have a leak that will have to be tracked down. As Bumper said, start at the water pump--it's the most likely source.Andy Baird http://www.andybaird.com/travels/
