Topic: rear wall structure and dimensions (Read 12 times) previous topic - next topic
Yahoo Message Number: 119222
Hi, I'm trying to get info on this area (mid-2000's twin king, not sure that matters). It appears that the space between the exterior rear wall and the interior rear wall tapers from wide at the shelf under the window to almost nothing at the floor. What vertical studs are in there? Do they taper vertically? I'm looking at this area to see if a wall mounted table could be swung down, and maybe recessed into the rear wall to allow the couches to pull out.
Regards, TS
