Topic: recommended interval to run genset (Read 2 times) previous topic - next topic
Yahoo Message Number: 118407
Read a blog post from a RVer who was told by an Onan service depot tech he should run his genset 1.5hrs every three weeks to maintain it in optimal condition. Previously we had heard 1 hour a month as a recommendation.  What does everyone here do? Our rig is stored most of the time so we have been going out once a month to drive it around and run the genset for and hour. Should we be doing this more often?
Richard
Re: recommended interval to run genset
Yahoo Message Number: 118409
Logic says that the extra 0.5hr run-time, a week earlier, will be insignificant compared to your current schedule, as far as keeping the generator running smoothly. If this adds up to a significant portion of your total run-time, however, then it may slightly advance the point at which wear-and-tear dictates an overhaul. This, of course, would be to the financial advantage of a service department. Not implying anything.
Yahoo Message Number: 118411
wrote: Read a blog post from a RVer who was told by an Onan service depot tech he should run his genset 1.5hrs every three weeks to maintain it in optimal condition. Previously we had heard 1 hour a month as a recommendation.
--- These RV generator FAQ pages from Cummins Southern Plains are very helpful:
 http://www.cummins-sp.com/support/rv_generator_operating_tips.htm
Yahoo Message Number: 118413
On Sat, 20 Nov 2010 16:06:03 -0000, "richardg1952" richardg1952@...> wrote:
Just running the genset is not all that helpful, it needs to be run under load. Turn on the a/c and an electric heater or such.
Don't know about everyone, but I see a lot of ads for used rigs with low gen hours meaning they were seldom turned on.
Yahoo Message Number: 118422
When you run your genset, make sure that you have a decent load on it, like running your A/C!
Glen w/SOB who should follow his own adviceL
Yahoo Message Number: 118429
Does anyone know, what having a load on the genset does that enhances the monthly exercise?
Thanks!
Rob Adams
2015 Mid Bath
Yahoo Message Number: 118430
On Sat, 20 Nov 2010 21:22:28 -0000, "sundog991" sundog99@...> wrote:
Two sides to a genset, the engine and the alternator. You want to exercise the alternator, get it warm, remove moisture.
Yahoo Message Number: 118443
On Sat, 20 Nov 2010 21:22:28 -0000, "sundog991" wrote:
 ">Does anyone know, what having a load on the genset does that enhances the monthly exercise? Two sides to a genset, the engine and the alternator. You want to exercise the alternator, get it warm, remove moisture."
Start the genset and then run the air conditioner; maybe turn on a space heater also or alternate the two.  Anything with high amp usage will put a load on the genset.
