Holding tank pesky valves October 27, 2010, 11:26:45 am Yahoo Message Number: 117808My holding tanks valves are very hard to operate, and suggestions on how to loosen the up. Thanks for any help. Doc 2000 FL
Re: Holding tank pesky valves Reply #1 – October 27, 2010, 11:33:49 am Yahoo Message Number: 117810Quote My holding tanks valves are very hard to operate, and suggestions on how to loosen the up. Thanks for any help. Doc 2000 FL Doc, alcohol on cotton balls to clean the blade, groove and shaft. Reach around to get the back side of that blade as best as you can. Then silicone spray. That is how I do it.Joe Hamm
Re: Holding tank pesky valves Reply #2 – October 27, 2010, 01:37:33 pm Yahoo Message Number: 117812On Wed, 27 Oct 2010 11:26:43 -0400, W DARRYLL PRICE DDS wdprice15@...> wrote:QuoteMy holding tanks valves are very hard to operate, and suggestions on how to loosen the up. Clean, then coat with Vaseline
Re: Holding tank pesky valves Reply #3 – October 27, 2010, 02:00:15 pm Yahoo Message Number: 117813Quote On Wed, 27 Oct 2010 11:26:43 -0400, W DARRYLL PRICE DDS wrote: My holding tanks valves are very hard to operate, and suggestions on how to loosen the up. Clean, then coat with Vaseline Vaseline is called for in the LD manual. Many who post here feel it is a magnet for dust and dirt compared to silicone spray. Either will work.Joe Hamm
Re: Holding tank pesky valves Reply #4 – October 27, 2010, 02:58:51 pm Yahoo Message Number: 117817wrote: Vaseline is called for in the LD manual. Many who post here feel it is a magnet for dust and dirt compared to silicone spray. -- I use Simple Green in warm water, a small, stiff-bristled brush (and old toothbrush can work OK), and the hose to scrub all the termination valve parts first. Vaseline gets sticky, gunks up, and attracts dirt, so like Joe and many others, I use silicone spray to lube the gate valves, inner valve slot, and handle shafts of the black and grey tanks. As ever, YMMV.Joan
