Topic: Jeep toad (Read 4 times) previous topic - next topic
Jeep toad
Yahoo Message Number: 112483
Hello to Jeep owners. I need some help setting up my, new to me, 1994 Jeep Sahara for towing. I also bought a standard tow bar that I want to connect to the Jeep. Can I just mount the brackets to the front bumper by drilling holes and bolting it on or do I need a better way to support the tow bar? I need to have running lights connected also. Are jeeps supplied with a simple plug-in connector that I can pig-tail to the LD, or how is that done? Finally, what is the procedure for preparing the jeep for recreational towing (four down)? Are all 4WD automatic tranny jeeps the same in that you must 1)Shift tranny into Neutral,2)Shift transfer case into Neutral,3)Start engine,4) Shift tranny into Drive and turn off engine? When towing do you then leave key in which position? Dale from Downey.
Re: Jeep toad
Yahoo Message Number: 112487
My setup is different from yours, but will answer what I can. I have a 99 Sahara with stick.
2000 TK
2014 Can-Am Spyder RT
Re: Jeep toad
Yahoo Message Number: 112491
The '95 would be a YJ model.  I believe that there was a vacuum disconnect for the front differential in those.  I don't know how that affects flat towing.  Best consult the owners manual for flat towing.  The stock front bumper is too flimsy to tow with.  Either a strong custom bumper that is well tied into the frame, or a towing baseplate like the ones from Blue Ox should be used.  You want the tow bar to be as close to level as possible, so a drop/raise receiver might be needed.  There are several ways to go about towing lights.  The most common is using diodes to keep the Jeep's electrical system isolated.  I ended up putting an extra socket/bulb in the taillight housing so the electrical systems stay independent.  Some people put manual disconnect hubs in the front wheels for towing purposes.  Also, are you planning on an auxiliary brake system?
HTH, Art
Art and Barbara
2002-2015 2002 LD MB
Art's blog
Re: Jeep toad
Yahoo Message Number: 112492
Art, Are the '94 & '95 models the same? Am I correct about what gears to select before towing? Where would be the best place to find a owners manual for my '94? Thanks and be well. Dale from Downey.
Yes, I have the breaking system figured out.
__ From: older_fossil no_reply@yahoogroups.com>
 Sent: Tue, May 11, 2010 1:42:49 PM
 Subject: [LD] Re: Jeep toad
