2004 26ft MB power to tv antenna amp and 12 volt plug April 26, 2010, 10:17:00 pm Yahoo Message Number: 112174GreetingsI own a 2004 26.5 ft Mid Bath, and am no longer getting power to the 12 volt plug and tv antenna amplifier mounted in the cabinet next to the tv in the rear of the coach. A optional 12 volt plug mounted along the wall of coach is still powered, but is fed from a separate power line. There is no power to the wires feeding the plug/amp box. The fuses all appear ok and all other electrical devices appear to function. Where does the line run between the plug/amp box and the fuse box? Any other suggestions?Glenn Oelker
Re: 2004 26ft MB power to tv antenna amp and 12 volt plug Reply #1 – April 27, 2010, 12:16:37 am Yahoo Message Number: 112178QuoteWhere does the line run between the plug/amp box and the fuse box? Any other suggestions?I believe I recall that if you pull the plate out, there is a fuse located behind it.Steve
Re: 2004 26ft MB power to tv antenna amp and 12 volt plug Reply #2 – April 27, 2010, 10:50:35 am Yahoo Message Number: 112184Quote GreetingsI own a 2004 26.5 ft Mid Bath, and am no longer getting power to the 12 volt plug and tv antenna amplifier mounted in the cabinet next to the tv in the rear of the coach. A optional 12 volt plug mounted along the wall of coach is still powered, but is fed from a separate power line. There is no power to the wires feeding the plug/amp box. The fuses all appear ok and all other electrical devices appear to function.Glenn, fuse #6 7.5 amp control this on the 2003 MB. Have to assume 2004 same. Check the backside of that amplifier to see if power is there.Joe Hamm
Re: 2004 26ft MB power to tv antenna amp and 12 volt plug Reply #3 – April 27, 2010, 08:10:51 pm Yahoo Message Number: 112196Thanks. I had checked fuse #6 previously, and it looked ok. When I just replaced it, things now working again!Glenn
