Topic: electrical power loss, diode isolator? (Read 6 times) previous topic - next topic
Yahoo Message Number: 111721
Batteries seemed charged and after one day of little use, nothing worked in the coach, even the monitor panel had no power. Driving home the speedo, fuel and charging gages did not work, radio powerless. The starter, headlights and cab ac all worked,I was able to drive home.
Can anyone shine some light on my problem?
Thanks,  Kelly
Re: electrical power loss, diode isolator?
Yahoo Message Number: 111730
About all I can say is that it seems unlikely the isolator is the issue. It would not kill the coach batteries, nor affect which gauges do not work. Fuses or a lifted ground connection somewhere are more likely. Diagnosis using a voltmeter will be necessary.
Yahoo Message Number: 111736
"Driving home the speedo, fuel and charging gages did not work, radio powerless."
 Kelly, it's hard to see how an isolator problem would affect dashboard gauges. You probably have a blown fuse under the dash, but there may be an additional cause lurking behind that, such as a bad ground. First thing to do is replace the fuse, though... then see what happens.
