Topic: 1985 LD engine info (Read 4 times) previous topic - next topic
1985 LD engine info
Yahoo Message Number: 111603
Want to know if anyone knows the specs on the original 1985, 350 Chevy engine. Need to know what HP that engine came with as it was originally in a 22 multy plan.  Thanks Reno
Re: 1985 LD engine info
Yahoo Message Number: 111611
350 cid, 155 hp @ 4000 rpm, 240 lb-ft @ 2800 rpm, 4bbl carburetor
Yahoo Message Number: 111635
Wow! They put a really low power version of the 350 in the LD. 300+ HP in not uncommon for the good ol' small block.
Yahoo Message Number: 111638
Carbureted 383 stroker with a RV cam and CARB approved manifold will pass California smog checks. You may need to rejet the quadrajet 4bbl.
Gobs of torque.
Yahoo Message Number: 111639
replacement intake manifold If you are in california, be sure your replacement intake manifold is CARB legal.
