Topic: Battery issues- do I just need a new cab one? (Read 4 times) previous topic - next topic
Yahoo Message Number: 111596
Do the following pull from the cab or coach batteries:
HWH Levelers with the joystick box?
 Starting the Generator with the remote start switch (switch inside the rig)?
 I think my low-amp battery issues are related to either the generator or levellers pulling on my cab battery.
 When I start the engine and use the levelers- I can actually see the battery switch drop significantly as I put load on the levellers!  Then the battery guage pops back up to normal the second I stop pushing on the leveler's joystick.  Weird.
 Everything will then look fine on the battery, so I turn off the leveler box and the cab engine.
 But then I start the generator -it can take 6-10 seconds of reving for the generator to finally turn over and start up-, not too long.  As the generator runs along fine, I turn on the cab battery and... du, dun, duuuuu...
 There's that low amp battery light on!  And the cab battery on low (on the "o" in the word "normal", whereas it was between the "m" and "a" just a few seconds before.
So is it the generator pulling too much from the battery?
Is the battery low?
 On our trip, if we then let the rig sit overnight, the battery would be back up to normal in the morning and we'd be fine.
 If we used the levelers even briefly at the dump station, the battery would be back to low amp when we restarted the engine.  But if we then drove highway speed, it would just jump back up to normal and the Low-Amp light would go off.
 Sometimes, on our trip on the drive to and from FL, after getting gas, the engine appeared to sould like a low battery in slow starting, but then the battery showed normal.  Very unnerving when your rig doesn't start right up.  Makes my stomach drop.
So do I just need a new cab battery?
 Is something wrong with my levelers, generator start, or electrical system? (please no)
 I bought the Optima Yellow Top battery (starting and deep cycle) exactly 2 years ago.  From Yellow Top reviews, that might be it's lifetime.  We have indeed been about 50,000 since installed.
 And I thought the generator pulled from the coach batteries- incorrect?
Please advise.
As always, thanks for the help,
Tessa in TX '92 MB - Ciao Baby!
Re: Battery issues- do I just need a new cab one?
Yahoo Message Number: 111601
Tessa,
 Since all the equipments you mentioned are not installed by Ford (or GM), there is no "defined standard" for the power source.  It could be the cab or the house battery.
 The quickest and easiest way to determine which is to simply disconnect the cab battery (you only need to disconnect the positive post) and then try the leveler or the generator.  If they don't work then they are connected to the cab battery.
Sam
Yahoo Message Number: 111604
Smart idea, Sam.
 And since I know the key has to be in the ignition and partially turned in order to move the levelers, the levelers must be coming off the cab battery - why didn't I think of that?
 I added the generator aftermarket, but am not sure which battery got it.  Your tip should help solve that conundrum.
Thanks for the help, Tessa
Yahoo Message Number: 111605
Good advice, EXCEPT please disconnect the NEGATIVE post, not the positive.
 ALWAYS remove the negative connection first from a battery, eliminating the chance of shorting the battery to ground with your tool.  By the same token, attach the negative connection last.
Rich Gort - 2000 MB - Birch Bay, WA
