Topic: Xtreme Vent by Coil n'Wrap (Read 2 times) previous topic - next topic
Yahoo Message Number: 111593
Has anyone installed Xtreme Vents for the black and grey water tank vents on top of the roof?  If so, did you need their coupler kit?  Did you have any problems installing them?  Would you recommend them?  I am thinking of ordering them at www.coilnwrap.com.  Thank you in advance for any information or opinions.
Monica NE 10
Monica
2017 MB
Re: Xtreme Vent by Coil n'Wrap
Yahoo Message Number: 111600
Monica
 I just installed one on my 2003 MB, but have not tested it yet. The Xtream vent was about .20" larger in diameter than the outside diameter of the LD vent pipe. I had to cut the metal cover down about an inch, then I used a short piece of 1 1/2" PVC that slipped over the LD vent line & into the Xtream Vent. The LD vent line outside diameter was trimmed a little to fit inside the PVC. All in all it was an easy job, but if I had to do it over I would have purchased the Coupler. I found the vent at Sportsman's Guide for just under $50.
Lon in Lake County, Northern CA
