Topic: Onan 4000 generator (Read 7 times) previous topic - next topic
Onan 4000 generator
Yahoo Message Number: 110886
Hi Group,  Just looked up Onan 4000 micro quiet generator that is put in the LD......Forum saying not quiet, eats up gas, etc.  Please let me know your experience.  Thanks, Sherry
Re: Onan 4000 generator
Yahoo Message Number: 110890
"Just looked up Onan 4000 micro quiet generator that is put in the LD... not quiet, eats up gas, etc."
 Sherry, to the best of my knowledge the Onan MicroQuiet 4000 is the quietest generator of its type (built-in 4,000W) on the market. It isn't silent, and the noise does bother some people, but there is no quieter alternative that can deliver this much power (and yes, you need this much power).
 As for fuel usage, the MQ 4000 uses about 1/3 to 1/2 gallon per hour, which is quite modest. I don't know of any 4,000W generator that uses less.
Bottom line: this is as good as it gets with today's technology.
Yahoo Message Number: 110893
wrote: Just looked up Onan 4000 micro quiet generator that is put in the LD......Forum saying not quiet, eats up gas, etc.  Please let me know your experience.
--- The "MicroQuiet 4000" is now badged as the "QG 4000" (QG = "Quiet Gasoline"); this link to its spec sheet shows the gasoline consumption per hour of use at no/half/full load levels -- the information is near the bottom of the sheet:
 http://www.cumminsonan.com/www/html/Common/pdf/specsheets/a-1421.pdf
The MicroQuiet/QG/whatever is a built-in gas generator; the nature of this beast is that, even "tuned" to factory specs, it produces noise and exhaust stink. I exercise my generator when a breeze is blowing and the nest-door neighbors aren't home! If I'm parked or camped next to or even fairly near another RV, I don't fire it up unless I have a "must-use" situation, e.g., powering my air compressor, and then I minimize the run time as much as possible. I think that gasoline consuption would only become a problem if the generator were run for hours on end; as one can see from the chart on the spec sheet, the gasoline use is "minimal", even at full load.
 Do they stink? Yes. Are they loud and occasionally obnoxious? Yes. However, I might attribute the same characteristics to a few people I know, but, like the generator, they can be useful and I'm usually glad to have them around.  YMMV.
Yahoo Message Number: 110897
Thank you Andy, Will be Leaving to go to LD tomorrow if the weather in Idaho and Nevada lets up.  Maybe they will start one up for me to listen to.  I have heard generators before but not ones that claimed quiet....and know that they must make some noise.
Yahoo Message Number: 110903
Don't forget that Honda makes an RV genset.  It is slightly quieter (IIRC) but it does weigh a little more.  It also has different mounting dimensions, so it's not a direct replacement.  But it is close enough that it should fit in a LD without too much trouble.
Just something else to consider.
 Oh, and when it comes to portables, don't overlook the Yamaha models.
-Victor
Yahoo Message Number: 110930
As I walk thru the campsite here I am almost embarrassed to run my 2001 Onan Micro quiet 4000. It seems to so much louder than any other genset running in the campground.  Others seem to be almost purring compared to ours.  Can this be corrected. Change muffler etc.
TIA Ed
Yahoo Message Number: 110945
Ed,
 I believe your 2001 LD has the Onan Emerald genset. That's a two cylinder of older design than the Microquiet, which I believe was introduced in the 2003 LD. My sense is that the Emerald was noisier by nature.
Terry
2003 26.5'RB
Gardnerville, NV
Terry
2003 26.5'RB
Gardnerville, NV
Yahoo Message Number: 110952
"your 2001 LD has the Onan Emerald genset. My sense is that the Emerald was noisier by nature."
 Terry's correct: the older Emerald generator used in older Lazy Dazes such as your 2001 was MUCH noisier than the MicroQuiet introduced in mid-2002.
Yahoo Message Number: 110963
Arrrrgghhhh !!  :-(      In Quartzsite seeking solar.
 Try Discount Solar on the northeast corner of Main Street and Plymouth.  If they've already closed down for the season, try RV Lifestyles, west of Love's.
Stay away from Solar Bill.
Linda Hylton http://map.datastormusers.com/user1.cfm?user=1167 http://earl-linda.blogspot.com
Linda Hylton
