Topic: Porable Generators (Read 3 times) previous topic - next topic
Porable Generators
Yahoo Message Number: 110881
Hello!
I'm beginning to look into portable generators. Honda, being one brand. I see I can get a new Honda EU-2000i for $899 (dry weight 47 lbs) and two for $1979 with parallel cables.
I was also wondering about  propane-powered generators.
I invite your thoughts and suggestions on the subject.
best, paul ___ 'Thriving not Surviving' See our websites at www. LazyDazers.com    www. Bike70th.net
www. SMARTERyellowpages.com & www. ReformUSCongress.org
Re: Porable Generators
Yahoo Message Number: 110882
 Sent: Tuesday, March 09, 2010 11:07 AM
 Subject: [LD] Porable Generators
Hello!
best, paul ___
Paul,
Guess it pretty much depends on what you want to do with the generator. For a portable, I sure wouldn't think of going propane (lower fuel energy density, more fuel container weight, less refill opportunity, normally no built-in fuel container on the generator, less selection of brands and models etc). If you aren't running an air conditioner and don't mind spending a bit more, solar has lots of appeal - - I can run everything in Yonder and never run the generator - - 'cept for that darn air conditioner.
bumper
Yonder
Minden, NV
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 110883
 Stick with gasoline-powered generators if possible...propane-powered ones are inefficient and you'll go through more fuel running the exact same thing as a gas generator.
 Whether you'll need one or two Honda 2000's depends on what you want to run.
If it's you're 13.5K A/C unit, one is probably not enough.  If you have a 15K A/C unit, you'll definitely need two (we run our 15K A/C unit with two Honda 2000's paralleled together).
 If you have a 13.5K A/C unit that you want to run with a generator, you might look, instead, at the Yamaha 2400-watt.  It advertises that it'll run *most* 13.5K A/C units.
Linda Hylton http://map.datastormusers.com/user1.cfm?user=1167 http://earl-linda.blogspot.com
Linda Hylton
Yahoo Message Number: 110889
"I'm beginning to look into portable generators."
 I'm assuming you don't have a built-in generator, because if you do, it'd be crazy to buy a portable. Well, the Honda EU series are as good as it gets. But before going further, ask yourself these questions:
 * Do I want this in order to run my air conditioner? (If so, you'll need two EU2000s or one EU 3000.)
* Where am I going to store one or two 60-pound generators?
 * Where am I going to store the gasoline can? (Must be in a vented exterior compartment.)
 * How am I going to feel about going outside every time I want to start the generator(s)? How about at 7:00 a.m. on a chilly morning when I want power to run the microwave oven or coffeemaker?
 * How am I going to keep the generator(s) from being stolen? (Happened to me at Quartzsite a few years ago, despite a locked antitheft cable.)
 * Would it make more sense to have an Onan generator installed in my rig, as Tessa and others have done? Advantages: indoor start button, no possibility of theft, no gas cans to carry.
Yahoo Message Number: 110909
Thanks, Linda. The Yamaha looks real interesting.
