replacing the fuel filter February 13, 2010, 03:19:26 pm Yahoo Message Number: 110034We are trying to replace the fuel filter on our LD, 2000 Ford 450 but can't figure out how to get it off. We found it, just can't seem to disconnect it. Any help is appreciated.Mark Matthews Austin
Re: replacing the fuel filter Reply #1 – February 13, 2010, 03:45:36 pm Yahoo Message Number: 110037wrote: We are trying to replace the fuel filter on our LD, 2000 Ford 450 but can't figure out how to get it off. We found it, just can't seem to disconnect it. --- This file on the Techsnoz message board will explain how to remove (you need a special tool) and replace the fuel filter; the link is:http://tinyurl.com/yl4ejm8Joan
Re: replacing the fuel filter Reply #2 – February 13, 2010, 03:57:33 pm Yahoo Message Number: 110038Mark, See my message # 50953. The tool you need is NAPA # 3321. Also be careful of the filter part number. There seems to be some confusion on some of the charts that give you the replacement numbers. The filter we needed on our 2000 is NAPA # 3595.Hope this helps,Rich Gort - 2000 MB - Birch Bay, WA
Re: replacing the fuel filter Reply #3 – February 13, 2010, 04:31:49 pm Yahoo Message Number: 110039Thank you Rich, that was what we needed. We got it off and switched out but it still won't start. Turns over but won't catch.
Re: replacing the fuel filter Reply #4 – February 13, 2010, 04:38:41 pm Yahoo Message Number: 110042Are you sure it's not your fuel PUMP and not filter? Be well. Dale.__ From: markrach2 markrach2@...> To: lifewithalazydazerv@yahoogroups.com Sent: Sat, February 13, 2010 2:28:42 PM Subject: [LD] Re: replacing the fuel filterThank you Rich, that was what we needed. We got it off and switched out but it still won't start. Turns over but won't catch.
Re: replacing the fuel filter Reply #5 – February 13, 2010, 04:42:06 pm Yahoo Message Number: 110043do you know where the fuel pump is located?
Re: replacing the fuel filter Reply #6 – February 13, 2010, 04:50:49 pm Yahoo Message Number: 110046Mark, Unfortunately, the fuel pump is inside the gas tank! The gas tank has to be dropped to get to it. Big bucks! Sure hope it's something else.Alex Rutchka, SE #4 '05 MB
Re: replacing the fuel filter Reply #7 – February 13, 2010, 04:55:08 pm Yahoo Message Number: 110047thanks for the info. I was afraid of that.
Re: replacing the fuel filter Reply #8 – February 13, 2010, 05:16:51 pm Yahoo Message Number: 110050Quote thanks for the info. I was afraid of that. Mark Your symptoms are identical to what mine were last summer. Had driven several miles, pulled into an RV park... next morning the engine would crank but not fire. Had it towed and the service facility had the diagnosis within 15 minutes. Took two days to get a pump but once they had it installed, everything was fine and I'm off down the road. Pump and strainer cost $194, labor cost $380 + tax so I was out the door for $591 bucks. And that was at a very small shop in a very remote area. Odometer read 41,796 and tech said that was typical for a pump replacement.Steve S. Lazy Bones & Jiggs
Re: replacing the fuel filter Reply #9 – February 13, 2010, 05:22:20 pm Yahoo Message Number: 110051Steve you just saved me a lot of time I think. I bet you are right. We unhooked the fuel line and the pump is not working. Thank you Steve.
Re: replacing the fuel filter Reply #10 – February 13, 2010, 06:01:56 pm Yahoo Message Number: 110052The fuel pump is most likely locatedd
Re: replacing the fuel filter Reply #11 – February 13, 2010, 11:35:54 pm Yahoo Message Number: 110066If you run out of ideas check out the electrical system. I had a '93 MB and after many intermittent problems and many mechanics switched out fuel filters, and fuel pump. I discovered accidentally that shaking one of the fuses that controls the fuel pump temporarily solved the problem. Then the wiring into the fuse box was repaired, and that solved the problem. Good luck. Doug__ From: markrach2 markrach2@...> To: lifewithalazydazerv@yahoogroups.com Sent: Sat, February 13, 2010 2:28:42 PM Subject: [LD] Re: replacing the fuel filterThank you Rich, that was what we needed. We got it off and switched out but it still won't start. Turns over but won't catch.
