Topic: Shelf Life of In-line Water Filters (Read 3 times) previous topic - next topic
Yahoo Message Number: 109710
I've got a couple of in-line RV water filters (Culligan & TastePure) that I used a few times last summer when filling the water tank, and I have kept them (capped) in the refrigerator since then.  Should I toss them are are the good to use again?  The Culligan site doesn't speak to this question.
Re: Shelf Life of In-line Water Filters
Yahoo Message Number: 109711
That should read "...or are they good to use again?"
Yahoo Message Number: 109712
I'd guess they are probably still good--keeping water filters in the fridge between uses is always a smart idea. But if you want to be sure, just hook 'em up and run a little water through them into a glass. If there's anything growing in there, you'll smell it. If not, go ahead and use them.
Yahoo Message Number: 109714
Chris,
 I've had no problem reusing filters after short period of use, by storing them open so they can completely dry out. This is with the larger cartridge type filters, so the media is exposed and will dry out readily. Not sure I'd be willing to reuse your wet-stored filter, as bacteria and bad things can grow in the fridge.
 If it's a pre-filter or sediment type, then you can sanitize it with a bit of chlorine bleach mixed in some water. Don't think this will work with an activated carbon filter as it will remove the chlorine to prevent it from reaching the whole filter.
bumper
bumper
"Yonder" '05 MB
"WLDBLU" glider trailer
Yahoo Message Number: 109719
wrote:
 I've got a couple of in-line RV water filters (Culligan & TastePure) that I used a few times last summer when filling the water tank, and I have kept them (capped) in the refrigerator since then.  Should I toss them are are the good to use again? --- Chris, are the Culligan and TastePure inline filters labeled "bacteriostatic"?  If so, and you wanted to save the costs of new filters, I'd just flush them well before using them again.
 I use an inline filter, one per "season", from the RV Water Filter Store that is advertised as having "bacteriostatic" properties:
 http://www.rvwaterfilterstore.com/WCInLineFilters.htm
However, I don't drink or cook with the "tank water"; if I did, I would have a different, and far more "agressive", filter set-up to handle the *great variances* in water quality wherever one fills the tank (or hooks up). You might want to check out the RV Water Filter Store; I have found their products, advice, and knowledge to be very good, and Rick answers emailed questions promptly.
Yahoo Message Number: 109722
wrote:
 But then how are you going to build up resistance to the "bad bugs" out there? --- Chiles and Sierra Nevada!
Yahoo Message Number: 109728
Andy, Bumper, Joan, Pat -- thanks for your comments.  We don't drink or cook with tank water either and use these filters to stop sediment and whatever "bugs" they will kill/trap.  So I think I'll see if they pass the sniff test and flush them and then reuse on our trip.
Chris Horst (leaving for Arizona tomorrow morning) 2002 30' IB Arvada, CO
