Topic: PC power supplies (Read 6 times) previous topic - next topic
PC power supplies
Yahoo Message Number: 108892
Someone wrote:  200 watt power supply put less drain on the batteries than  a 500 watt PS?> You need to remember that a 500 Watt power  supply doesn't use 500 watts, and neither does a 200 watt. Those are the maximum  ratings of what the supply can provide to a load. If you have a 75 watt load  hooked up to each supply there would be no difference in what the supplies would  draw. But because the wiring and circuitry is more robust in the 500 watt supply  to be able to supply more power than the 200 watt can, then it would lose a  little more power running itself. This inefficiency would be wasted power if you didn't need the larger ability. I doubt that it would be very significant.
I've seen people add up the wattage ratings of devices without  regard to what the actual usage would be to arrive at estimates. But these estimates are worst case scenarios, and can have little to do with reality. Best  to get an ammeter, a 'Kilowatt' meter is excellent also to monitor actual power  usage.
Hope this was helpful, Ron and Bluebelle, a  '99TKB
Re: PC power supplies
Yahoo Message Number: 108894
'Hope this was helpful, Ron and Bluebelle, a  '99TKB'
Thanks Ron
_,_._,___
