Topic: Doghouse? ..Raining inside the coach (Read 5 times) previous topic - next topic
Re: Doghouse? ..Raining inside the coach
Yahoo Message Number: 108535
Ok, this is at least the 4th time in recent days someone has referred to the
Yahoo Message Number: 108539
Pat and Gary,
 The way we dealt with issues of condensation in our LD was to cover vents that weren't being used (summer or winter) with the cheap Reflectix vent covers available at most RV stores.  The only vent that was never covered with one of those covers was the one in the bathroom.
 Whenever we were using heat from any source (stove, electric space heater, furnace, etc.), we had that bathroom vent open at least one inch.  Sometimes, while cooking, for example, we had more than one vent or window open.
 When using the air conditioner, all vents were closed (except for brief use when showering, cooking, etc.
We did not have any major condensation issues.  Hope this helps.
Sharon N.
Crossville, TN
Yahoo Message Number: 108541
"we are getting a lot of condensation on the roof vent and fan metal frames."
 Lazy Daze sells covers that are custom-fitted to the vents and the escape hatch (if you have one. They're made of heavy vinyl lined with polyurethane insulating foam, and snap into place  with supplied hardware. I wouldn't be surprised if you can find these at local RV suppliers as well, since the vents are pretty standard. (Note that a slightly different cover is required for vents with Fan-Tastic fans, because their mounting screws are differently positioned. Be sure to specify which type of vent you have in mind.)
 Another possibility is the widely available "vent plug" cushion, a 14" square by 3" thick foam block usually covered in fake lambswool. You can shove it up into the vent, and it stays in place by friction. Most RV suppliers carry these.
 However, the vinyl covers have a couple of advantages. First, they cover the *whole* vent, not just the inside. Also, they fold flat for storage, unlike the vent plugs. But either one will prevent condensation.
